Introduction: RGB LED Adaptive Camouflage (chameleon) Using Ebot / Arduino
This is a really great and simple project. It uses a color sensor to sense the color of the background and displays it on the RGB LED strip.
I used an Ebot Microcontroller but you could also use any other microcontroller such as arduino uno.
Step 1: Assemble Materials
Electronic components:-
1 x Ebot Microcontroller ( you can also use arduino or any other microcontroller )
1 x Color sensor
1 x RGB LED Strip
6 x Jumper wires
For testing you could get some different colored sheets.
Step 2: Setup
The setup is really easy
1. take the RGB LED and solder three jumper wires on GND, Do, and +5v and connect them to GND pin, output 0 pin, and 5v pin respectively on the microcontroller.
2. Next with the color sensor connect the the
GND --> GND pin on the microcontroller
voltage pin--> voltage pin on the microcontroller
s --> A0 pin on the microcontroller
Step 3: Assembly
After you are done with the setup attach the color sensor to the strip facing down.
Step 4: Code
{ //Initialisations ebot_setup();
//Pin Modes
strip0.begin();
strip0.show();
pinMode(0, OUTPUT); //RGB LED
pinMode(A0, INPUT); //Color Sensor
void loop()
{ if(colour(A0)>=182 && colour(A0)<= 279) { colorWipe(&strip0,0,45,97,25);
} else if(colour(A0)>=79 && colour(A0)<= 149) { colorWipe(&strip0,0,105,14,25);
} else if(colour(A0)>=21 && colour(A0)<= 43) { colorWipe(&strip0,255,221,0,25);
} else if(colour(A0)>=340 && colour(A0)<= 352) { colorWipe(&strip0,191,3,0,25);
} else { colorWipe(&strip0,0,0,0,25); }
you could add more and more if statements to make the sensor sense more colors.
Step 5: Video
Finally as shown in the video you could add different color papers to test how it works.
