Introduction: Save Cash - Use Trash. Home-made Tools - Hand-powered Sander. Ponceuse Fabrication Mason. Bricolaje Una Lijadora De Disco
A hand-powered sander made from scrap. We're powering down on all household items, including tools. I use a mitre block but it's never accurate enough so I wanted a sander to obtain a better mitre joint. By altering the guides you can also use it to square up any sawn edges. This little project ironically uses hand and power tools to create a hand-powered disc sander. I used the power tools to save time, as we have a lot of work at the moment but it can be made using hand tools alone. The disc, for example does not have to be round and if you use a thicker chipboard you will not need the router..
Public Domain Music from Nowick Gray and Eugene Neptune, GreenEarthForever: http://archive.org/details/Nimba
Une ponceuse fabrication maison des matières récupérées. J'ai utilisé les outils électriques pour la vitesse, mais tout le travail peut être fait avec des outils à main.
Una lijadora de disco de material recuperado. He utilizado las herramientas eléctricas para la velocidad pero todo el trabajo se puede hacer con herramientas de mano.
