Introduction: Sega Genesis Model 1 Region Modification
This instructable will tell you step-by-step how to modify your Model 1 Sega Genesis to it may play other region games with a simple toggle switch.
Step 1: Parts Needed
1. Model 1 Sega Genesis
2. Soldering Iron
3. Solder
4. Three small gauge wire
5. Switch
6. Dremel
7. File
8. Philips head screw driver.
9. Patience
2. Soldering Iron
3. Solder
5. Switch
6. Dremel
7. File
9. Patience
Step 2: Disassemble
In this step, we're going to completely dismantle the system.
Step 3: Locating the Proper Jumpers
Now that the board is exposed, you'll need to locate the proper jumpers labeled "JP1" and "JP2".
"JP2" has a bridge between it. Scratch this out using whatever you like.
Also, now would be a good time to heat up your soldering iron.
Step 4: The Wires
Take three different colored wires, preferably the same legenth. Strip the ends and add a bit of solder to the stripped ends. Braiding them is optional.
Step 5: The Switch
Find your switch, and add a bit of solder to the contact points.
Step 6: The Jumpers
Now, we're going to wire the jumpers.
Add a bit of solder to the jumpers, and then add the wire.
Please see the image notations below.
Step 7: The Switch (remix)
Solder the wires to the switch. Be mindful of which one is supposed to be on the center contact point of the switch.
Step 8: Cartridge Door.
Since there's a difference in cartridge size, the cartridge door will need to be modified as well. This is easy.
Again, follow the image notations.
Step 9: Finding a Home for the Switch
Now, you're going to have to bore out a space for the switch.
Follow the image notations.
Step 10: Re-Assemble!
Before you completely re-assemble this, you've probably noticed that the shield might be blocking the wires for the switch. Cut the shield. Don't cut it if you found a better placement.
After that, re-assemble it and bask in the glory of your Sega.
