Introduction: Simple Prybar for Pallets
This is a simple prybar made to break pallets, while saving more of the wood.
This project will require one length of 1" square tubing, 1/8" wall, approximately 6' in length.
Welding machine.
Hacksaw or other tool to cut tubing.
Wire brush or other tool to prep surfaces for welding.
Welding machine.
Step 1:
Plan and make cuts in your tubing so that you end up with:
2 pieces which are 5 1/4" overall length, with one end cut at 90° and the other cut at 45°
1 piece which is 90° at both ends, and 5 1/4" overall length
1 piece, approximately 4' 8", one end cut at 15°, the other is the end of the handle.
Clean all pieces in preperation for welding.
Step 2:
Assemble and weld so that the final product resembles the prybars in the previous images.
If you would like, you can finish the other end with a hockey tape handle.
The reason for the 15° angle is apparent in the animation*. It makes it easy to drop the breaker into place.
*click image to see animation
Step 3:
I thought I would include a few photos of this breaker in action, in order to make clear why the angles are cut the way that they are.
