Introduction: Space Phone
This is a toy similar to two cans connected with a string to be used as a communication device. Instead of creating voices this device creates sounds similar to what you would hear in star trek or star wars. I have seen these available commercially but thought that it would be really easy to make on my own. The design is simple, just a really big spring and two plastic cups. The key to the design is the large spring and the diaphragm. The spring may be hard to find, the diaphragm is crucial because if it doesn't vibrate correctly you won't get the cool space like sound out of it.
Step 1: Materials
The materials you will need for this are Two Solo cups, a large spring, and a thumb tack
Step 2: Assembly
You will now need to poke a hole in the bottom of each solo cup right in the middle. After doing this you will need to simply thread the coil of spring through the hole in each cup. stretch out the spring to a moderate tension and begin making noises!!!
