Introduction: The IKEA Robot Lamp
Welcome to the SM-1 project from ArduinoArts.com!
(A.K.A as the Annoying IKEA Lamp)
We are proud to introduce you to the SM-1 project (aka the Annoying IKEA lamp), as part of the Toy hacking contest from the SeeedStudio.com friends.
The project consists in modifying an IKEA 5€ lamp and adding it some sensors, lights, sound and movement to make it more fun. (even that we have made a few other hacks to this same lamp as the Iphone photostudio).
Here is a sample diagram of what we have in mind (and hope to be able to make it real!).
Part 1
So, the first thing that we need is the lamp:
and the Grove Toy Kit from our friends of SeeedStudio.com
The basic idea is to detect if there is movement or not (with the motion detector); if there is movement we start the servo no.2 and play a pre-recorded message. Otherwise, there is working the servo no.1 and a different pre recorded message.
Reading the state of the motion sensor is very simple: we assign and digital input and read the state. The result is a binary data 0 or 1 (quiet or movement). Doing a simple loop and based on this result we start one or another gadgets.
The sound recorder on it´s own, can only play 4 pre-recorded sounds via external signal. To record them there has to change a switch from play to record position and press the desired button (it has 4 buttons, one for each sound) and record it (should be less than 15sec each). Once recorded we change the switch to play position, and access them by the play() function declared on the code.
The servos work in a very simple logic, they have 3 cables: positive, negative and digital data. The first two give the servo the power to move (max 7v) and the third one goes to an digital output where it receives the information on which degree should it be, and the change begins. We are using the sweep tutorial code in this example.
Part 2
We continue the developing of our SM-1 Lamp Robot, this time we are doing hacks on the lamp to install one servo, the one that will move the lamp head to the sides (as if the lamp looks to each side).
Here is the detail of the lamp head:
Let´s dissarm all of it. Also we should remove all the electrical parts of the original lamp.
We are not going to use a 220v lamp, but instead we are going to need all this space to install some sensors.
This is how it shoul look without the lamp head. See in the background the lamp head allready without the electrical parts:
Now, we are using some spare parts (also from IKEA), from the EXPEDIT furniture. They come with some metal supports in case you are attaching the furniture to the wall (which i never do), and these parts fit perfectly in the lamp and hold perfectly also the servo.
Now, lets drill the lamp head to attach it to the servo arm.
And this is how it looks!!! Looks almost as terminator isn´t it? ;-)
We also added a second servo (later) and improved the installation on the lamp servo as seen on this pictures:
Part 1
Part 2
Step 1: Adding Light and Base
Part 3
So, we now have a first prototype working, it talks, it moves, it knows when you move, but what is a lamp without a light? and also a lamp has to look nice in your house, so we are making a neat base to show the guts of the lamp, but with style.
For the lamp, we are using the IKEA OLEBY sun powered lamp, (this time we are only using the led lamp, the solar charger we will keep it for another project). This is the lamp (allready without the solar charger base):
we had to modify it a little bit; add a screw for fixing it to the lamp base and extracting the switch system.
The installed switch was digital, and only worked when there was current. If we are controlling this led lamp with our Seeeduino board trough a digital output, when we set the D/O as LOW, there will be no current, and when set back to HIGH, we would have to manually start the lamp with the switch. I guess this system was installed to prevent accidental discharge of the solar powered batteries.
This is the inside of the lamp:
now, we add a resistor (to protect the led, because the original was on the PCB of the switch) and some cable to close up the lamp.
now it´s time to install it on the lamp:
Now, with the lamp light installed, it´s time to make a Base for the lamp, and for this we are using a photo frame… and guess where it´s from? IKEA again!
This is a very simple step, so we are going to show only the results:
Step 2:
Part 4
So, we finally have a working prototype of the lamp.
We have installed a base, a led lamp, 2 servos, a motion sensor, a noise sensor, and 3 axys accelerometer and an audio accesory capable of recording and playback of 4 different sounds (thanks to seeedstudio.com).
The working logic of the lamp is the following:
If Noise is detected:
Turn on lamp
Play audio#3 (i´m trying to sleep here!)
Make a sweep left – right – left movement witht he lamp servo (as a negative head movement).
Rest servos on 90 degreees
Turn off lamp
If motion is detected:
Turn on lamp
Move to the left side (base servo and lamp servo).
Play audio#2 (are you sarah connor?)
Move to the right side (both servos also)
Return to rest position (90 degrees on servos)
Turn off lamp
If max hight is detected (with the 3 axys readed value):
Play sound#4 (Oh Yeah!)
Now it´s time to clean the code that is a mess!!!
Turn on lamp
Turn off lamp
Turn on lamp
Turn off lamp
Step 3: Adding a 3axys Control Remote and Aut/manual Switch
Part 5
Here are a few of the improvements i have done on the lamp (check the details on the photo gallery below):
-Improved the fix on the servos
-Servo to rise the lamp (instead of the base rotation).
-Base light fixed
-Manual Mode with 3 axys realtime remote control.
-Better fix on the speaker (sounds louder) and audio jack out.
The Auto and Manual Mode:
I added a switch connected to a digital input on the Seeeduino Board, to control which part of the code i want to be running on the lamp. This was controlled by an IF statement, if switch is on, play the auto code, if off, play the manual mode.
-Auto Mode: this is the standard code of the previous versions; the lamp responds to the state of the sensors. In this case we have only 2 sensors: motion and noise (as you can see on the previous post)
-Manual Mode: since the position change on the second servo (from the base of the lamp to the middle in order to rise the lamp, there was no sense on using the 3 axys accelerometer on the lamp (we can know when the lamp is up with the position of the servo). So i managed to make a really good use of this 3 axys accelerometer: as a control remote. If we have the lamp on manual mode, we can control the servos as a responde on the position of 2 axys (X and Y). It´s really fun. Also added a sound response to the hight position, this time instead of the “Get me down” of the previous version, an “Oh yeah”, as you can see on the video.
There is a lot of improvement to make on the lamp, here are a few things I think should be improved:
-The code: i´m more a creative maker than a coder… it just need to be improved A LOT!!!!
-Independent power for the servos: these are high torque servos, and the consume a lot of power when working (specially when moving at high speed or when they are forced). You can see the problem on the leds when the servos are moving. It also triggers some times undesired audio playback (i guess the shield resets on low power).
-360º movement on the lamp: adding a third servo on the lamp head for real movement, will add weight, but i think is worthy.
-Stronger servo for the rise: or a weight balance to help the servo rise the lamp.
-Improved audio shield: to playback more audio messages. Right now it can only playback 4 pre-recorded messages. We could be doing a more attractive robot with more phrases and ideas triggered by more sensors, more states, etc.
-Ethernet / WiFi connection: to be controlled / control social networks.
-LCD screen: to display messages (alike the audio shield).
-RGB leds on the base: to express different “feelings” trough colors.
-Jump: this is something YouTube viewers have complained a lot on the last video; it doesn´t jump! we should be able to do something to make it jump?
-Base Movement: i was thinking on adding 4 spider kind of legs, but it will be on a not so near future…
-Base light fixed
Step 4: The Code
The Code:
Here is the first versión of the code, need a lot of improvement. There are some libraries i´m not using on the main loop, but can be used for modifying the behavior of the lamp.
So Enjoy! ;-)
@MrLndr
/* Made by @MrLdnr for the SeeedStudio Toy Hack contest
Base don the examples of the motion sensor, notion sensor, knob servo, and others.
www.arduinoarts.com*/
#include <Servo.h>
const int buttonPin = 4; // switch state
int buttonState = 0; // variable for reading the pushbutton status
//Servo Setup
Servo myservo2;
Servo myservo; // create servo object to control a servo
int pos = 0; // variable to store the servo position
int pos2 = 0; // variable to store the servo position
int val1;
int val2;
//LED SETUP
const int ledPin2=5;//Base light
const int ledPin=12;//Lamp Light
int countlamp2 = 0; // number of loops on servo
//Noise Setup
const int thresholdvalue=300;//The threshold noise response
//Accelerometer SETUP
int ystate;
int xstate;
#include <Wire.h>
#define MMA7660addr 0x4c
#define MMA7660_X 0x00
#define MMA7660_Y 0x01
#define MMA7660_Z 0x02
#define MMA7660_TILT 0x03
#define MMA7660_SRST 0x04
#define MMA7660_SPCNT 0x05
#define MMA7660_INTSU 0x06
#define MMA7660_MODE 0x07
#define MMA7660_SR 0x08
#define MMA7660_PDET 0x09
#define MMA7660_PD 0x0A
class Acceleration
public:
char x;
char y;
char z;
char index;
char control;
char state;
int audiodelay=1000;
void mma7660_init(void)
Wire.begin();
Wire.beginTransmission( MMA7660addr);
Wire.send(MMA7660_MODE);
Wire.send(0x00);
Wire.endTransmission();
Wire.send(MMA7660_SR);
Wire.send(0x07); // Samples/Second Active and Auto-Sleep Mode
Wire.send(0x01);//active mode
void setup()
mma7660_init(); // join i2c bus (address optional for master)
Serial.begin(9600);
//Motion Sensor
pinMode(6, INPUT);//Use pin 2 to receive the signal outputted by the module
// Lamp light and base light
pinMode(ledPin, OUTPUT);
pinMode(ledPin2, OUTPUT);
//SERVOS
//AUDIO
DDRD |= 0x0C; //D2 and D3 in write mode;
PORTD &= 0xF3; //D2 and D3 set to low;
//Noise sensor on Analog 0
//SWITCH
pinMode(buttonPin, INPUT);
void rec_2_begin()
PORTD = (PORTD | 0b00000100)&0b11110111;
void rec_2_stop()
PORTD &= 0xF3;
void play_2()
delay(audiodelay);
PORTD &= 0xF3;
// function to control the segment_3
void rec_3_begin()
PORTD = (PORTD | 0b00001000)&0b11111011;
void rec_3_stop()
PORTD &= 0xF3;
void play_3()
delay(audiodelay);
PORTD &= 0xF3;
// function to control the segment_4;
void rec_4_begin()
PORTD = PORTD | 0b00001100;
void rec_4_stop()
PORTD &= 0xF3;
void play_4()
delay(audiodelay);
PORTD &= 0xF3;
void check_move()
int sensorValue = digitalRead(6);
if(sensorValue==1)
//digitalWrite(ledPin,HIGH);
//Serial.println(sensorValue, DEC);//Print the state of the signal through the serial monitor.
//servo1();
else
//digitalWrite(ledPin,LOW);
//servo2();
void servo1_right()
myservo.attach(9);
for(pos = 90; pos < 180; pos += 1) // goes from 0 degrees to 180 degrees
{ // in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(10); // waits 15ms for the servo to reach the position
/*play_2();
delay(1000);
for(pos = 180; pos>=90; pos-=1) // goes from 180 degrees to 0 degrees
void servo1_left()
myservo.attach(9);
for(pos = 90; pos > 1; pos -= 1) // goes from 0 degrees to 180 degrees
play_2();
delay(1000);
for(pos = 1; pos<=90; pos+=1) // goes from 180 degrees to 0 degrees
void servo1_return()
myservo.attach(9);
int posact = myservo.read();
if (myservo.read()>90){
for(pos = posact; pos > 90; pos -= 1) // return to 90
else {
for(pos = posact; pos <=90 ; pos += 1) // goes from 0 degrees to 180 degrees
void servo2_right()
myservo2.attach(10);
for(pos = 90; pos < 120; pos += 1) // goes from 0 degrees to 180 degrees
myservo2.write(pos); // tell servo to go to position in variable 'pos'
/*play_2();
delay(1000);
void servo2_left()
for(pos = 90; pos > 60; pos -= 1) // goes from 0 degrees to 180 degrees
play_2();
delay(1000);
void servo2_return()
int posact = myservo2.read();
if (myservo2.read()>90){
else {
void servo1_no()
myservo.attach(9);
for(pos = 120; pos>=90; pos-=1) // goes from 180 degrees to 0 degrees
void servo2()
for(pos2 = 110; pos2 < 140; pos2 += 1) // goes from 0 degrees to 180 degrees
myservo2.write(pos2); // tell servo to go to position in variable 'pos'
delay(15); // waits 15ms for the servo to reach the position
void servo1R()
myservo.write(90);
myservo.detach();
void servo2R()
myservo2.write(90);
myservo2.detach();
void lampblink()
//int sensorValue = digitalRead(6);
//if (sensorValue =1){
//delay (1);
//delay (1);
//else
void lamptest()
for (int i=0; i<100; i++)
digitalWrite(12, HIGH);
delay(50);
digitalWrite(12, LOW);
delay(50);
void lampoff()
//delay (2000);
digitalWrite (ledPin, LOW);
// accelerometer
void Ecom()
unsigned char val[3];
int count = 0;
val[0] = val[1] = val[2] = 64;
Wire.requestFrom(0x4c, 3); // request 3 bytes from slave device 0x4c
while(Wire.available())
if(count < 3)
while ( val[count] > 63 ) // reload the damn thing it is bad
val[count] = Wire.receive();
count++;
// transform the 7 bit signed number into an 8 bit signed number.
Acceleration ret;
ret.x = ((char)(val[0]<<2))/4;
ret.y = ((char)(val[1]<<2))/4;
ret.z = ((char)(val[2]<<2))/4;
ystate = ret.y;
xstate = ret.x;
Serial.print("x = ");
Serial.println(ret.x,DEC); // print the reading
Serial.print("y = ");
Serial.println(ret.y,DEC); // print the reading
Serial.print("z = ");
Serial.println(ret.z,DEC); // print the reading*/
char reading = 0;
void loop()
Ecom(); //checking accelerometer state
digitalWrite(ledPin2,HIGH);
buttonState = digitalRead(buttonPin); // read the state of the switch
if (buttonState == HIGH)
lampblink();// turn LED on:
myservo.attach(9); // attaches the servo on pin 9 to the servo object
myservo2.attach(10); // attaches the servo on pin 9 to the servo object
val1 = ystate; // reads the value of the potentiometer (value between 0 and 1023)
val1 = map(val1, 30, -30, 0, 179); // scale it to use it with the servo (value between 0 and 180)
myservo2.write(val1); // sets the servo position according to the scaled value
val2 = xstate; // reads the value of the potentiometer (value between 0 and 1023)
val2 = map(val2, -30, 30, 0, 179); // scale it to use it with the servo (value between 0 and 180)
myservo.write(val2); // sets the servo position according to the scaled value
if (ystate < -15) {
play_3();
else {
//checking for noise
int sensorValue2 = analogRead(A0);//noise sensor
Serial.println(sensorValue2);
if(sensorValue2>thresholdvalue)
Serial.println("YES");
//digitalWrite(ledNoise,HIGH);
play_4();
//lampoff();
lampblink();
servo1_no();
servo1_no();
servo1R();
delay(1000);
else
lampoff();
//checking for motion
int sensorValue = digitalRead(6); //motion sensor
if(sensorValue==1)
Serial.println("Move");
//movestate =1;
lampblink();
//servo2();
servo2_right();
servo1_right();
play_2();
delay (1000);
servo2_return();
servo1_return();
servo1_left();
servo2_left();
play_2();
delay (1000);
servo2_return();
servo1_return();
//delay(1000);
else
//digitalWrite(ledNoise,LOW);
//servo2();
servo1R();
servo2R();
lampoff();
//play_2();
//movestate =0;
So Enjoy! ;-)
@MrLndr
#include <Servo.h>
//Servo Setup
Servo myservo2;
int val1;
int val2;
//LED SETUP
//Noise Setup
int ystate;
int xstate;
#include <Wire.h>
class Acceleration
public:
char x;
char y;
char z;
char index;
char control;
char state;
Wire.begin();
Wire.send(0x00);
void setup()
Serial.begin(9600);
//Motion Sensor
//SERVOS
//AUDIO
//SWITCH
void rec_2_begin()
void rec_2_stop()
PORTD &= 0xF3;
void play_2()
delay(audiodelay);
PORTD &= 0xF3;
void rec_3_begin()
void rec_3_stop()
PORTD &= 0xF3;
void play_3()
delay(audiodelay);
PORTD &= 0xF3;
void rec_4_begin()
void rec_4_stop()
PORTD &= 0xF3;
void play_4()
delay(audiodelay);
PORTD &= 0xF3;
void check_move()
if(sensorValue==1)
//servo1();
else
//servo2();
void servo1_right()
myservo.attach(9);
/*play_2();
delay(1000);
void servo1_left()
myservo.attach(9);
play_2();
delay(1000);
myservo.attach(9);
else {
void servo2_right()
/*play_2();
delay(1000);
void servo2_left()
play_2();
delay(1000);
else {
void servo1_no()
myservo.attach(9);
void servo2()
void servo1R()
myservo.write(90);
myservo.detach();
void servo2R()
myservo2.write(90);
myservo2.detach();
void lampblink()
//delay (1);
//delay (1);
//else
void lamptest()
delay(50);
delay(50);
void lampoff()
//delay (2000);
// accelerometer
void Ecom()
int count = 0;
if(count < 3)
count++;
Acceleration ret;
ystate = ret.y;
xstate = ret.x;
char reading = 0;
void loop()
if (ystate < -15) {
play_3();
else {
play_4();
//lampoff();
lampblink();
servo1_no();
servo1_no();
servo1R();
delay(1000);
else
lampoff();
if(sensorValue==1)
//movestate =1;
lampblink();
//servo2();
servo2_right();
servo1_right();
play_2();
delay (1000);
servo2_return();
servo1_return();
servo1_left();
servo2_left();
play_2();
delay (1000);
servo2_return();
servo1_return();
//delay(1000);
else
//servo2();
servo1R();
servo2R();
lampoff();
//play_2();
//movestate =0;
