Introduction: The Single Most Effective Way to Get Rid of a Sunburn
This is my first instructable, and is only going to be short because its an extremely easy and effective method to removing a painful sunburn.
This method was recommended to me by my friends mother, who is a nurse. I hope this helps many a painful sunburn to recede or disappear quickly.
EDIT: 6/26/16
As this instructable has seen over 6mm views since I first published it, I've decided to edit it for more clarity & for safety concerns.
Step 1: Gathering Materials
You will need a total of six things.
  1. A bathtub to do this in (preferably ceramic, so it wont stain)
  2. A pitcher
  3. A rag that you don't mind getting stained
  4. Water
  5. Three bags of black tea (I use Earl Grey)
  6. Ice
Step 2: Fill the Pitcher
First things first, strip down, because you don't want to get any of your clothes wet. Fill the pitcher with lukewarm water and soak the tea bags in it - the water should be just warm enough to help the tea brew. When you have the water almost black, like the picture, then move on to step 3.
DO NOT use hot water! As a sunburn is a first degree burn, adding more heat to a burn will exacerbate the effects and cause further damage to your skin. Use only lukewarm water at most.
Step 3: Healing the Wound
Once the water has cooled to a warm/lukewarm temperature (add your ice now to speed this)
Dunk the rag into the tea, and dab it onto the sunburn. Do not wipe it off! Leave it on and let it be absorbed into your skin. Once its dry, re-apply as necessary, but never wash it off. If you do this process before bedtime, you can go to sleep and give it time to work its magic. In the morning you can wash it off in your shower. Hopefully, your sunburn will be substantially subdued, but remember: the sooner you can apply the tea after you get the burn, the quicker and more effective it will be.
Note: I had a severe sunburn and I also used the tea bags straight up, dabbing them directly onto my skin. You may use as many "coats" of tea as you want, but the more the better.
