Introduction: Tor Relay on Raspberry Pi 2 & 3
I'm creating this Instructable because I'm tired of seeing so many outdated guides on how to setup a Tor Relay on a Raspberry Pi 2... 95% of the guides I found led to installing some out of date bundle of Tor (0.2.5.x) instead of the current (0.2.7.x).
Step 1: Parts Needed
You need the following parts:
- Raspberry Pi 2
- Power supply
- Network cable/connection to the Internet
- Micro SD card with Raspbian (you can find all necessary installation instructions here:http://www.raspbian.org/RaspbianInstaller)
Step 2: Getting Started
In your terminal type:
sudo raspi-config
Now you are going to go to option 1 and expand your usable space on your micro sd card from 2 gigs to the actual size of your card.
Next, again:
sudo raspi-config
Now you are going to option 2 to change the password of your Pi from "raspberry" to something secure.
Step 3: Add a User
sudo adduser tor
[enter]
Enter a secure password!
[enter]
Enter the password again
[enter]
sudo nano /etc/sudoers
[enter]
Add the following line at the bottom of the page:
torALL=(ALL) ALL
Step 4: Updates
Before we get started with updates for the Pi, let add the Tor Projects package repository.
sudo nano /etc/apt/sources.list
and this to the bottom of the list:
deb http://deb.torproject.org/torproject.org jessie main
Now in your terminal run:
sudo apt-get update
sudo apt-get upgrade
Step 5: Add the Tor Projects GPG Keys
In your terminal run:
gpg --keyserver keys.gnupg.net --recv 886DDD89
Then run:
gpg --export A3C4F0F979CAA22CDBA8F512EE8CBC9E886DDD89 | sudo apt-key add -
GPG Key source for verification: https://www.torproject.org/docs/debian.html.en
Step 6: Install Tor
sudo apt-get update
sudo apt-get install tor deb.torproject.org-keyring
(This will take a long time so be patient)
Step 7: Configure Tor
In your terminal enter:
sudo nano /etc/tor/torrc
Highlight everything (Mac = Command + A) and replace it with the config below:
SocksPort 0 Log notice file /var/log/tor/notices.log RunAsDaemon 1 DataDirectory /var/lib/tor ControlPort 9051 CookieAuthentication 1 ORPort 443 DirPort 80 ExitPolicy reject *:* Nickname TypeYourNicknameHere ##Remove the # before RelayBandwidthRate & RelayBandwidthBurst to throttle bandwidth speed. #RelayBandwidthRate 1024 KB # Throttle traffic to 1024KB/s #RelayBandwidthBurst 2048KB # But allow bursts up to 200KB/s ##optional #ContactInfo TypeYourEmailHere DisableDebuggerAttachment 0
Control + x to close / save the file.
In terminal enter:
sudo /etc/init.d/tor restart
Step 8: Install ARM (Tor Graphical Controller)
In terminal type:
sudo apt-get install tor-arm
Then to launch ARM type:
sudo -u debian-tor arm
Step 9: Secure Ports:
Next in your terminal enter:
sudo nano /etc/iptables/rules.v4
Now copy and paste this above the word "commit"
## Allows all loopback (lo0) traffic and drop all traffic to 127/8 that doesn't use lo0 -A INPUT -i lo -j ACCEPT ## allow incoming SSH -A INPUT -p tcp --dport 22 -j ACCEPT ## allow Tor ORPort, DirPort -A INPUT -p tcp --dport 433 -j ACCEPT -A INPUT -p tcp --dport 80 -j ACCEPT ## ratelimit ICMP echo, allow all others -A INPUT -p icmp --icmp-type echo-request -m limit --limit 2/s -j ACCEPT -A INPUT -p icmp --icmp-type echo-request -j DROP -A INPUT -p icmp -j ACCEPT ## to log denied packets uncomment this line (I uncommented it for you). -A INPUT -m limit --limit 5/min -j LOG --log-prefix "iptables denied: " --log-level 7 -A INPUT -m state --state RELATED,ESTABLISHED -j ACCEPT -A INPUT -m state --state INVALID -j DROP
If you have any questions, feel free to post a comment and I'll respond as soon as I can!
