Introduction: Twinkling Branches Room Divider
About: Hi everyone! I'm a hardcore DIY'er, I've published 11 DIY books, just produced my own TV show called Make Your Mark for PBS/APT, I make YouTube videos every week and I'm buried under a mountain of craft suppl…
Add a little magic to your home with a twinkling branches room divider!
Step 1: Watch the Video Tutorial Here!
Step 2: You'll Need
6 - 24" long 1"x3" pine boards
6 - 60" long 1"x3" pine boards
24 -1 1/4" wood screws
18 - 3/4" wood screws
Drill
4 - 2" long hinges
Thick galvanized wire
Wire cutters
Americana Decor Chalky Finish in Rustic and Serene
Paintbrush
Wax
Sanding block
12 - 60" long branches
Step 3: Create the Frames
Create four 24" x 60" frames by connecting each corner with two 1 1/4" long wood screws
Connect the frames together using the 2" long hinges
*make sure that the frames are in a zigzag pattern
Drill three screws on the top and bottom of each frame leaving 1/4" sticking out
Step 4: Paint and Prep
Attach the galvanized wire around the 3/4" screws from top to bottom
on each of the three frames
*You will be attaching the branches to these wires
Paint the edges of the room divider with the Rustic Chalky Finish paint
*You can be messy with this color
When dry, rub wax over the Rustic paint
Paint the entire room divider in the Serene Chalky Finish and let dry
Step 5: Add the Branches
Sand the edges of the room divider to expose the Rustic color underneath and to give the room divider a shabby chic/antique feel
Cut about 30 - 5" long pieces of wire
Attach the branches to the wire that was stretched from the top to the bottom
of each frame of the divider
*Clip the branches that extend over the edges
Wrap the white Christmas tree lights around the branches and plug it in!
