Introduction: Vintage Frame Ring Display!
About: Hi! My name is Natalie! I have an awesome husband that lets me be a Play-at-home mom of 3! We homeschool and do projects daily! Check out my blog Doodlecraft for more awesomeness!
A fabulous tutorial on repurposing/upcycling
Vintage Frames into Ring Display cases!
Gorgeous right?
I just love to see ALL my rings in one place!
Step 1: Supplies and Getting Started!
You'll need:
Frames
old thick towel
velvet material
cardboard (or the backing board that fits into the frame)
tools:
scissors
hot glue/gun
popsicle stick
Start with some empty frames.
I've been fortunate enough to pick up
awesome vintage frames at yard sales
and thrift stores for under dollars...
But they can be any style of frame you like!
And essentially these can be pretty cheap!
Paint, glaze, style your frame anyway you like!
Step 2: Let's Begin!
Now, measurements will be different based on your
frame size and the thickness of the towel.
My frame's opening is 5 by 7...so this is based off of that size.
(it can hold about 20-22 rings)
Cut your towel into strips to fit the width of your frame.
I went an inch bigger (8") so I could cut it down at the end.
Start by rolling your towel tightly until it is at least
1 inch in diameter, up to 1.5 inches.
Then cut the towel.  Unroll it and cut 5 more towels that size.
So you'll have 6 for your frame.
Roll them up and test them out with a ring or 2...
Cut the edges so they fit in the opening of the frame...trim on both sides.
Step 3: Hot Glue Time!
Take the rolled towels and hot glue them right onto your cardboard!
Once the rolls are secure you are ready for the velvet.
The velvet will weave in and out of the rolls...
with hot glue securing it to the cardboard as well.
Spread apart your glued rolls and run some hot glue on the cardboard.
Insert your velvet and press into the crease with a tongue depressor...
Making sure to get the velvet secured tightly to the cardboard.
Repeat for each roll.
Should look like this from the side
Put a dab of hot glue on the end of each roll and flatten
the velvet down on the cardboard so it will fit in the frame.
Step 4: Putting It Together!
Hot glue the cardboard all around the edges
and press securely in to the back of the frame!
Let it cool...
And then, mass produce!  These are great gifts!
Keep in mind for Christmas!
Step 5: Fill Them Up!
Perfect for Photos of rings for sale...
or displaying your rings at craft shows!
Or just having awesome vintage frames to hold
your collection of vintage rings!
I love them!  I've got all my rings where I can see them!
These are mostly costume and cocktail type rings...
I would keep the expensive jewelry out of sight just for safety's sake.
(not like I have any)
Thanks for checking out my tutorial!  Let me know if you make some!
Please vote for me in the Vintage and Jewelry contests!
And check out my blog for more fun!
:) Nat
