Introduction: New Trailer; Completed March '09
I don't have the instructions for this trailer writen out, though I find the visual just as helpful. I will say that it is all brazed,and made of 3/4" conduit, of which I sanded the galvanizing off before I started brazing(helth reasons), with exception to the front , which is made of 1" thin wall steel tubing(80") , a 13" peice of 5/8ths ridgid steel tubing(tapped on both ends) to accept two bolts(one top and one bottom) and a 17" x 3" x 3/16ths" piece of flat steel, which I drilled 5/8ths" holes one inch from each end, then bent to a 90deg 2" from each end, then that pc. was welded to the front of the trailer and the thinwalled construction of the rest of the front was welded as well, thanks to the expert welding skills of my step brother.
I tried to think this all the way through befor I started, but sometimes you just have to build one to really know things like how it balances, pulls, how much wieght is put on your back tire of the bike and so forth, so in saying that I am going to cut this in half, just ahead of the middle up rights and braze a rack on the back, over the tire on the trailer, doing that will take the wieght off of the rear tire of the bike, other than that the trailer pulls real well, trails right behind the bike, and after the refab, it will be balanced much better. I was thinking about putting the rack, that i will be making to go over the trailer tire, on a hinge, so that it could double as a lid for the refabed trailer.
