Introduction: Kermit the Frog Clone
Some days ago SHIFT! asked me if I can post a Kermit tutorial
Sooooo, here it is
It is not the perfect replica but it resembles in some manner
So I called this a Kermit clone
Searching online I found out that there is a muppet comics out there
never knew that :P
Experiment with this instructable and do some tweaks and you will be there
You can also ask some advices from puppets and stuff.com
Materials needed for your puppet
Fleece I recommend you buy a good quality one because if the fabric is to thin the seams will show
Eyes I was looking for a small plastic bal to cut in two ,you can find them at corners in machines similar to gum drop machines , but of course I did not find this and I made them from polystyrene
Hot glue sticks
Contact cement
Craft rubber
Some aluminium wire
Craft paper
Sponge
Tools :
Scissors
Cutter knife
Needle
Brush for the contact cement or a stick
Pins
Marker pen
Sewing machine
Hot glue gun
Step 1: Cut and Glue
Make your stencils on craft paper(it is cheap and you can afford to do mistakes)
Take the stencil for the head
Mark and cut two pieces from the sponge you have(it is a good idea to use a thinner one than the one I had ,because when the sponge is too thick it is a little difficult to work with the puppet in the end)but you can also use what you find around the house
Glue the pieces using contact cement
Step 2: Cut Fabric and Stitch
Mark it using the same stencil as for the head
Stitch first around the head (no 1 in picture)
Then stitch the upper segment (no2)
Cover the sponge with the fleece and then…
Step 3: Make Mouth Board
Trace the mouth board by folding a piece of cardboard and placing it in the puppets mouth,
Trace around the sponge
Cut a little smaller than the tracing because this will give the big dimples in the corner of the mouth
I forgot to do this
Glue fleece to mouth board using hot glue
Fit board inside puppets mouth and first glue the corners
Then the middle of each side(top and bottom)
Glue the rest
Step 4: Glue Mouth Board
Glue the rest
Step 5: Cut Sponge and Fabric for Body
Take two pieces of fleece and fold in two
Trace the body stencil on them
Stitch
Cut four pieces of sponge using the same stencil
Glue together and fit the segment inside the fleece part
Step 6: Stitch Head to Body
Stitch the head to the body using a ladder stitch
Step 7: Make Neck Piece
Step 8: Make Arms and Fingers
Make arms and fingers
This I made by sewing a thin hose and a wider one
Cut the wide one for arms and the thin for fingers
You can add some aluminium wire to the fingers to make it easier to shape the fingers
Stitch the fingers inside the wide hose
Place wire inside fingers
Close fingers
Stitch fingers to the body
Step 9: Add Eyes and Tongue
Make or buy the eyes and glue them in place(i made them from polystyrene)
Make the tongue from pink craft rubber and glue with hot glue
make the dark part of the mouth also from craft rubber
Step 10: Try Out Your Puppet
Try out your puppet and have fun
:P
I have some puppets on my Etsy shop if you want to check them out
https://www.etsy.com/shop/TheCircusCottage?ref=seller-platform-mcnav
First Prize in the
Comic Contest
Toy Challenge
