Introduction: MonoXover 2-way Pre-amp Audio Crossover
You can purchase a fully assembled monoXover from me here.
Features:
- 2-way 2nd-order crossover (ie, it can be used with any speaker that has a woofer and a tweeter)
- compact low cost design using easily available parts
- easy to adjust the crossover frequency
- adjustable equalizer for the woofer and tweeter
- can convert stereo to mono, or can select either left or right channel only
- published design you can use and modify as needed
Step 1: How It Works
check the schematic below. (click the [i] in the upper left of the image to get to the higher resolution version)
the input jack is on the left and the output jack on the right. the headers above the circuit explain what each section does.
If you want the stereo-to-mono function, install both R3 and R4. if you want just the left channel or the right channel, install just one of them.
The relative output volume for the woofer and the tweeter is set by the pots R6 and R7
Step 2: What You Need
- 100mH inductor (2 pcs) with under 100 ohm internal resistance. example: J.W.Miller 5900-104-RC
- 3.5mm stereo jacks (2 pcs). example: CUI SJ1-3515N
- 1k potentiometer (2 pcs). example: Bourns 3386F-1-102LF
- 22 to 33 ohm resistors (2 pcs).
- film capacitor (2 pcs). see next step for value
- resistor (2 pcs). see next step for value
- experimenter pcb to solder to, such as a SchmartBoard
Step 3: Choosing Your Crossover Frequency
If you are modding an existing speaker, normally it has a crossover built in already. The frequency is often in the spec sheet. However, the built-in crossover often uses a low cost 1st-order circuit that requires setting a higher frequency crossover. Often it is desirable to lower the crossover frequency when using a higher order crossover. The limitation on this is that the tweeter can be damaged by sending too much low frequencies to it.
I'm not an expert on crossover frequencies, search the web if you need more info on this topic.
The table gives correct values for a 2nd order Linkwitz-Reilly crossover.
All values are based on a 100mH inductor, because this yields the highest load resistance, and thus the largest output signal given a fairly weak mp3 player output.
I've attached an excel spreadsheet with live formulas so you can calculate any crossover you like.
- Choose the crossover frequency you want (Fc)
- Read across to the C1/C2 column for the correct cap values
- Read across to the R5/R6 column for the correct parallel load resistors (the total load is R, but since we use a 1k pot, we put another resistor in parallel with it to match R)
L (mH) | C1, C2 (uf) | R (tot) | Fc | R7, R8 (ohm) | R5, R6 (ohm) |
100 | 0.120 | 456 | 1453 | 1000 | 840 |
100 | 0.100 | 500 | 1592 | 1000 | 1000 |
100 | 0.082 | 552 | 1758 | 1000 | 1233 |
100 | 0.068 | 606 | 1930 | 1000 | 1541 |
100 | 0.056 | 668 | 2127 | 1000 | 2014 |
100 | 0.047 | 729 | 2322 | 1000 | 2695 |
100 | 0.039 | 801 | 2549 | 1000 | 4018 |
100 | 0.033 | 870 | 2771 | 1000 | 6720 |
100 | 0.027 | 962 | 3064 | 1000 | 25552 |
Step 4: Putting It Together
I made a pcb for this circuit. however, it is not hard to build on a generic experimenter board.
OUTPUT:
woofer output is on the left channel (channel 2).
woofer level control is R7: CounterClockWise for maximum.
tweeter output is on the right channel (channel 1).
tweeter level control is R8: ClockWise for maximum.
