Introduction: Water Deodorant Spray
this instructable show how to put water in a spray deodorant can .
Step 1: Gather Your Materials
pliers
EMPTY adjustable disposable lighter ( im not sure if this can be done with non adjustable lighters also)
EMPTY spray deodorant can
syringe
water ( not shown in picture)
Step 2: Disassemble the Lighter
after you assemble the lighter their should be a nozzle on the under side of the nozzle there should be a brass end cap, remove this. this may require pliers or it may not.
(check picture 2 for more details)
Step 3: Insert Here
insert the nozzle from the lighter in to the business end of the syringe
Step 4: Extraction
extract all of the contents of the spray can
to do this push down on the spray can and pull back the syringe
do this until the can creates a vacuum of sorts.
( no way to better explain it)
Step 5: Injection
inject water or whatever into the the can. do this until you feel there is enough contents in the spray can .
next, inject the spray can with air
do these two things the same way as step four but instead you will be injecting not extracting
Step 6: Have Fun
this can be done with many liquids (except diesel)feel free to color the water or use some other liquid like lighter fluid just be careful and have fun.
