Introduction: SafeString Alternative to Arduino Strings for Beginners
Update 15th May 2023: V4.1.27 – revised defines for Arduino Zero added PlatformIO versions
Update 8th March 2021: V4.0.0 revised returns to more closely match Arduino Strings. indexOf, stoken, etc now return int and return -1 for not found / end of tokens. Check warnings for where code changes needed.
Update 8th January 2021: V3.0.1 added SafeStringReader.end() and support for SAMD boards and minor fix to readUntilToken
Update 6th January 2021: V3.0.0 added SafeStringReader, BufferedInput, loopTimer, millisDelay
V2 Warning!! substring() in SafeString V2 excludes the endIndex. Check your usage of substring when updating from V1 and remove(idx) has been rename removeFrom(idx)
Update 22nd December 2020: V2.0.8 Added buffers to SafeStringStream, and protect() to BufferedOutput
Update 19th December 2020: SafeString V2.0.6 Added SafeStringStream, BufferedOutput, readUntilToken() and clarified stoken() V nextToken(), renamed nl() to newline() to avoid ESP32 conflict
Update 12th November 2020: SafeString V2.0.0 added wrapping of char* and char[] in a SafeString and added typing shortcuts for the createSafeString... macros. (See Wrapping existing char arrays in a SafeString below). Fixed error in replace( )
Update 21st September 2020: SafeString V1.0.6 added processBackspaces() and retain nextToken delimiters for later inspection. Added SafeString_Menu example
Update 15th June 2020: SafeString V1.0.1 available
Update 14th June 2020: SafeString now installable via Arduino Library Manager
Introduction
This SafeString library is designed for beginners to be a safe, robust and debuggable replacement for string processing in Arduino. This tutorial shows you how to use SafeStrings for your Arduino string processing. As concrete examples, it includes a simple sketch to check for user's commands, separated by spaces or commas, without blocking the program waiting for input. It also include an OBD data processor where the existing char* is warpped in a SafeString for processing. See the User Commands Example and the ODB data processing examples below.
This instructable is also available online at String Processing in Arduino for Beginners, also see SafeString Library Documentation
Contents
- Quick Start-- Step 2
- Passing SafeStrings to methods as references and returning SafeString results
- Wrapping existing char arrays in a SafeString
- An ODB data processing example
- Using SafeString for class variables
- Working with Arrays and structs of C-strings
- Mixing SafeString and c-string methods
- Method 'static' SafeStrings and readFrom() and writeTo()
- A String Tokenising and Number Conversion Example
- User Commands Example
- Converting between String and SafeString
- Differences between Arduino Strings (WString.cpp) and SafeStrings
- SafeString Error Flags and Controlling SafeString Error messages and Debugging
- What is wrong with Arduino String processing
- Conclusion
Also see Arduino For Beginners – Next Steps
How to write Timers and Delays in Arduino
SafeString Processing for Beginners (this one)
Simple Arduino Libraries for Beginners
Simple Multi-tasking in Arduino
Arduino Serial I/O for the Real World
Why should you use SafeString for your Arduino string processing.
The previous option for string processing in Arduino was Arduino Strings. Both Sparkfun and Adafruit advise against using the Arduino String class but Arduino Strings are very safe and usable, if you follow the guidelines in Taming Arduino Strings. On the other hand SafeString gives you complete control over your memory usage and a richer set of readers, parsers and text functions and detailed error messages that make debugging easier. You can also build SafeString content by calling the well know print( ) methods on them. SafeString also are better then Arduino Strings for processing data returned by third party libraries in char[]s. There are also a few errors in the Arduino String class that SafeString fixes.
String processing using low level C character arrays (using strcat, srtcpy etc) is a major source of program crashes and is not recommended.
- SafeStrings are easy to debug. SafeStrings provide detailed error messages, including the name of SafeString in question, to help you get your program running correctly.
- SafeStrings are safe and robust. SafeStrings never cause reboots and are always in a valid usable state, even if your code passes null pointers or '\0' arguments or exceeds the available capacity of the SafeString.
- SafeString programs run forever. SafeStrings completely avoid memory fragmentation which will eventually cause your program to fail and never makes extra copies when passed as arguments.
- SafeStrings are faster. SafeStrings do not create multiple copies or short lived objects nor do they do unnecessary copying of the data..
- SafeStrings can wrap existing c-strings. Wrapping existing char* or char[] in a SafeString object allows you to safely perform string manipulations on existing data.
Unlike Arduino Strings and C character arrays, SafeStrings will NEVER crash your program due to out of memory, null pointers, buffer overrun or invalid objects.
V2.0.0 of SafeStrings adds creating SafeStrings from existing char[] and char* See Wrapping existing char arrays in a SafeString below
V2.0.5 of SafeString adds non-blocking Serial I/O and SafeStringStreams. See Arduino Serial I/O for the Real World
V3.0.0 of SafeString adds loopTimer and millisDelay and BufferedInput. See How to write Timers and Delays in Arduino, Simple Multi-tasking in Arduino
V4.0.0 of SafeString revises function returns to more closely match Arduino Strings. In particular indexOf now returns and int, and returns -1 if not found.
Any Arduino board
Step 1: Quick Start
Installation of SafeString library:
SafeString is now available via the Arduino Library Manager, thanks to Va_Tech_EE
Start the Arduino IDE, open the library manager via the menu Tools->Manage Libraries..
Type SafeString into the Filter your search search bar and mouse over the SafeString entry and click on Install, as shown above
Then under File->Examples you should now see SafeString listed (under Examples from Custom Libraries) and under that a large number of examples sketches.
Under File->Examples you should now see SafeString listed (under Examples from Custom Libraries) and under that a large number of examples sketches. Under the File->Examples->SafeString ,the SafeString_Test directory has numerous examples of how the SafeString methods work. Start with the SafeString_ConstructorAndDebugging example and then SafeStringFromCharArray,
SafeStringFromCharPtr and SafeStringFromCharPtrWithSize.
Typing shortcuts for createSafeString.. macros
In SafeString V2, as well as the createSafeString( ) macro, it introduces three (3) more macros createSafeStringFromCharArray( ), createSafeStringFromCharPtr( ) and createSafeStringFromCharPtrWithSize( ) (see Wrapping existing char arrays in a SafeString below). SafeString V2 also adds the typing shortcuts cSF( ), cSFA( ), cSFP( ) and cSFPS( ) respectively for these macros. These shortcuts are #defined at the top of SafeString.h.
// define typing shortcuts
#define cSF createSafeString
#define cSFA createSafeStringFromCharArray
#define cSFP createSafeStringFromCharPtr
#define cSFPS createSafeStringFromCharPtrWithSize
You can change them as you wish or add your own defines.
A First Example Sketch
As a first example try the sketch above, SafeString_Example1.ino,
Some of the important statements in this sketch are:-
createSafeString(msgStr, 5);
creates an empty SafeString large enough to hold 5 char (plus a terminating '\0'). Here a global SafeString, msgStr, is created, but you can also create temporary local SafeStrings inside your functions. In all cases there is never any heap fragmentation.
SafeString::setOutput(Serial);
set the output Stream to send the error messages and debug() to
msgStr = F("A0");
msgStr += " = ";
msgStr += analogRead(A0);
builds up the string to be output.
msgStr.debug(F(" After adding analogRead "));
will print the title followed by the details and contents msgStr (but only if setOutput( ) has been called).
Running this sketch, SafeString_Example1.ino, produces the output above
The error message,
Error: msgStr.concat() needs capacity of 8 for the first 3 chars of the input.
Input arg was '598'
msgStr cap:5 len:5 'A0 = '
After adding analogRead msgStr cap:5 len:5 'A0 = '
indicates that the msgStr is not large enough to hold the
whole message. It needs to be increased to at least a capacity of 8. Note that the msgStr is still valid. If an operation cannot be performed the SafeString is just left unchanged.
Edit the createSafeString(msgStr, 5); to read increase it size to 10, i.e. SafeString_Example1a.ino
createSafeString(msgStr, 10);
Re-running the sketch (SafeString_Example1a.ino) after this change gives the following complete output
10 9 8 7 6 5 4 3 2 1
After adding analogRead msgStr cap:10 len:8 'A0 = 604'
A0 = 604
Finally comment out or remove the setOutput statement, i.e. SafeString_Example1b.ino
// SafeString::setOutput(Serial);
Re-running the sketch (SafeString_Example1b.ino) after this change gives the following output
A0 = 487
All the debug() output has been suppressed. Without the setOutput( ) statement the error messages are also suppressed, so you should include a setOutput( ); statement while testing.
Step 2: How to Add Text to a SafeString
There are a number of ways to add text to a SafeString. As shown above you can use = and += to add text, numbers and other SafeStrings. You can also pass an initial string value to createSafeString( ) , e.g.
createSafeString(msgStr, 10, "A0");
If the SafeString is not large enough to hold the initial value, the result will just be an empty SafeString. If SafeString::setOutput(Serial); has been called then an error message will also be output.
Note: Only an inline "string" can be used as the initial string value for the createSafeString( ) macro.
You can also use the concat() methods to do the same. e.g. SafeString_Example1c.ino
The clear() method clears out any existing text in the SafeString. The concat() and clear() methods return a reference to the SafeString so you can chain calls as shown in SafeString_Example1c.ino
Serial.println(msgStr.concat(" = ").concat(analogRead(A0)));
For more format control you can use the familiar print() methods to print to a SafeString. e.g. SafeString_Example1d.ino (see above) To add the analog reading in HEX form you use
msgStr.print(analogRead(A0),HEX);
All the print/write methods are available for adding to SafeStrings. The output from SafeString_Example1d.ino is (the exact output depends on the analog reading)
A0 = 0x25A
SafeString also has prefix() methods and the -= operator to add text to the front of the SafeString, e.g. SafeString_Example1e.ino
msgStr.clear(); // remove the initial value
msgStr -= " = 0x";
msgStr.prefix(F("A0")); Serial.println(msgStr);
Other SafeString methods()
SafeString has a range of other methods to work on text :- compareTo, equals, == , != , < , <= , > , >= , equalsIgnoreCase, startsWith, endsWith, endsWithCharFrom, startsWithIgnoreCase, setCharAt, charAt, [ ] (access only), indexOf, lastIndexOf, indexOfCharFrom, substring, remove, removeBefore, removeFrom, removeLast, keepLast, replace, toLowerCase, toUpperCase, trim, toLong, binToLong, octToLong, hexToLong, toFloat, toDouble, stoken, read, readUntil, readFrom, writeTo, stoken, nextToken, processBackspaces.
The two 'unsafe' methods in V1 of this library:- readBuffer and writeBuffer, have been removed in V2 and replaced with the safe readFrom() and writeTo() methods.
Step 3: Passing SafeStrings to Methods As References and Returning SafeString Results
The Arduino compiler will issue an error or warning if you try and write an incorrect method using SafeString arguments or returns.
Note: You can also work on familiar char* to pass and return arguments and just wrap them in SafeStrings within the method for processing. See Wrapping existing char arrays in a SafeString below and the SafeString_ReadFrom_WriteTo.ino example sketch.
Enabling Arduino Compiler Warnings
To see these error and warning easily, make the following settings in the Arduino preference dialog (above)
Open Arduino File->Preferences and untick Show verbose output during compilation and just below that turn on Compiler Warnings: That is set Compiler Warning to something other than None, for example Default. These settings will make it easy to see the warnings/errors referred to below.
How to pass a SafeString as an argument to a method
When you define a method that has a SafeString
argument you MUST declare it as a reference, SafeString& e.g.
void test(SafeString& strIn) {
If you forget to use the & when defining the function, you will get an error message like the the following
. . . /SafeString.h: In function 'void setup()':
. . . /SafeString.h:109:5: error: 'SafeString::SafeString(const SafeString&)' is private
SafeString(const SafeString& other ); // You must declare SafeStrings function arguments as a reference, SafeString&, e.g. void test(SafeString& strIn)
TestCode:30:11: error: within this context
test(str);
The first line of the errors tells you where the function with the error was called from, e.g. test( ) was called in setup()
The third line tells you what the error was
and a little further down you will see which function call caused the error
test(str);
That tells you that it is the test( ) method that is missing the SafeString & in its definition. Go the where you wrote the test( ) method and add a & to the end of SafeString. That is change test(SafeString .. ) to test(SafeString& … )
Declaring the method SafeString& argument as a reference means that any changes you make to it in the method will immediately update the SafeString that you passed to the method when you called it. There is only ever one copy of each SafeString and it is that one copy which gets all the changes applied to it. You could also declare the argument as a SafeString pointer, e.g. SafeString *str, but it is easier to code the method using a SafeString & reference.
Cannot write methods with const SafeString &argument
With SafeString V2 you cannot write a method with a const SafeString & as an argument. You have to use a non-const SafeString & argument as shown above This is because SafeStrings that wrap existing char arrays (see Wrapping existing char arrays, below) are 'cleaned up' in each SafeString function. This 'clean up' protects the SafeString from the results of invalid c-string operations on the wrapped char array (see Mixing SafeString and c-string methods, below), but this means the SafeString & can not be a const. If you define a method with a const SafeString & as an argument, then you compile you will get an error/warning message like
passing 'const SafeString' as 'this' argument discards qualifiers [-fpermissive]
Compiling for Uno/Mega will issue a warning (with the setting Compiler Warnings: default). While compiling for an ESP32 will give an error.
How to pass a SafeString result back from a method
Unlike the String class, SafeString does not support returning a SafeString from a method. To return results in a SafeString, you must update one of the SafeString & arguments you passed to the method. For example write a method that takes the number of loops and returns a SafeString for printing you would use SafeStringMethods.ino
void loopCountStr(int num, SafeString& str) {
str = "loop count = ";
str += num; // update it
// str returned via SafeString& arg
The caller of this method has to provide the SafeString, as an argument, for the result to be returned in. The SafeString provided as an argument can be a global SafeString OR a local SafeString created in the code calling the loopCountStr method.
Arduino Strings let you return a String or String & as the return type from the method. It does this by coping the result and passing that copy back. SafeString only ever has one instance of each SafeString and never creates another copy. If you try to pass a SafeString back as the method return you will get either a complier error or warning as shown below.
Here are two examples that do not work and the errors and warning they produce.
SafeStringMethod_Error_1.ino uses SafeString loopCountStr(int num) and the compiler gives the error message
That is to return a SafeString you need to pass it into the method as a reference and then update it as in SafeStringMethods.ino
SafeStringMethod_Error_2.ino uses SafeString& loopCountStr(int num) and the compiler give the warning message
warning: reference to local variable 'str' returned
That is the method loopCountStr is trying to return a reference (a pointer) to the local SafeString that was created on the local method stack. The method stack is completely discarded when the method returns so the data referenced is no longer valid. You MUST heed this warning and change the code to remove it, because sometimes a sketch with this warning will appear to work, but it will ultimately fail and cause a reboot.
Step 4: Wrapping Existing Char Arrays in a SafeString
When working with existing code and libraries you often have existing char[] or char* that contains the string data you want to process or where you want to put the results. The macros createSafeStringFromCharArray( ) or cSFA( ) and createSafeStringFromCharPtr( ) or cSFP( ) and createSafeStringFromCharPtrWithSize( ) or cSFPS( ) let you wrap the data in a SafeString for processing using the existing allocated char[] without copying the data to/from a SafeString. See the example sketches SafeStringFromCharArray.ino, SafeStringFromCharPtr.ino and SafeStringFromCharPtrWithSize.ino that are included with the SafeString V2 library.
Once you have wrapped the existing char[] in a SafeString, any changes you make using SafeString methods are reflecting in the underlying wrapped char[].
The difference between createSafeString() / sSF() and the other createSafeStringFrom..() versions is that the createSafeString() macro creates a char[] (either globally or on the local stack) where as the other createSafeStringFrom..() macros all just wrap an existing char[] and do not use any extra char[] storage. Because the createSafeStringFrom...() macros wrap the existing data, any changes made via the SafeString are reflected in the existing data.
For example using cSFP to wrap the “test” string updates when operations are performed with the SafeString :-
char str[] = "test"; // existing char[]
Serial.println(str); // prints => test
cSFP(sfStr,str); // use typing short cut to create a SafeString, sfStr, that warps the existing data.
sfStr.toUpperCase(); // changes the underlying data
Serial.println(str); // prints => TEST
On the other hand using cSF( ) and sfStr = str, takes a copy of the initial data and so does not change the underlying char[]
cSF(sfStr, strlen(str)); // create as SafeString large enough to hold a copy of the existing data
sfStr = str; // copy str to sfStr
sfStr.toUpperCase(); // does NOT change the underlying data
The macro createSafeStringFromCharArray( ) or its typing shortcut cSFA( ),wraps an existing char[..]. The char[ ] must have a specified size e.g.
char testData[25] = "initial data";
Then
cSFA(sfData, testData); // SafeString from a char[25]
gives you safe access to the testData[25] and sfData.debug() => SafeString sfData cap:24 len:12 'initial data'
The sfData capacity is only 24 since one extra char storage is need to correctly terminate the c-string.
Data accessed by char* is much more common than a char[ ] with a specified size. For char* you can use either createSafeStringFromCharPtr() / sSFP( ) or createSafeStringFromCharPtrWithSize( ) / cSFPS( ) to wrap the data in a SafeString.
The macro createSafeStringFromCharPtr() or its typing shortcut sSFP( ), wraps the existing c-string pointed to by the char* and sets the SafeString capacity to it strlen(). This macro is very useful for processing incoming data. The macro checks for a NULL pointer but assumes the c-string pointed to is correctly terminated. The SafeString lets you safely process the data, but, because the SafeString's capacity is set to the strlen of the input data, you cannot extend the len. e.g.
char *dataPtr = testData; // a pointer to the data
Then
cSFP(sfData, dataPtr); // SafeString from a char*
gives you safe access to the initial data and sfData.debug() => SafeString sfData cap:12 len:12 'initial data'
The sfData capacity is only 12 since that is the only valid data length SafeString can determine from the char *.
The macro createSafeStringFromCharPtrWithSize() or its typing shortcut sSFPS( ), wraps the existing c-string pointed to by the char* and sets the SafeString capacity to the specified size. This macro is very useful for outputting data to a result c-string. The macro checks for a NULL pointer but assumes you are correctly specifying the number of chars the result array can hold. The result array needs to be one bigger for the terminating null. e.g.
char testData[25] = ""; // testData can hold 24 characters + terminating '\0'
Then
cSFPS(sfData, dataPtr, 25); // SafeString from a char* that can hold (25-1) = 24 char + terminating '\0'
gives you safe access to the initial data and sfData.debug() => SafeString sfData cap:24 len:12 'initial data'
NOTE: It is very important that the size passed must be the size of the underlying char[] pointed to by the char*. If in doubt use cSFP( ) which will use the strlen(dataPtr) as the capacity.
Step 5: An OBD Data Processor Example
An car ODB data processor will be used as an example application using these SafeString wrappers. The initial attempt at this processor (local copy here) using Arduino Strings and malloc() and strdup() only ran for 30secs before the ESP32 rebooted due to heap fragmentation. That problem was solved using SafeString V1. The SafeString_OBD.ino sketch illustrates how to use the SafeString V2 wrapping macros to do the processing.
The typical code to read the OBD data (using ELMduino library) is
myELM327.sendCommand("AT SH 7E4"); // Set Header BMS
if (myELM327.queryPID("220101")) { // BMS PID = hex 22 0101 => dec 34, 257
char* payload = myELM327.payload;
//size_t payloadLen = myELM327.recBytes; // But ELMduino terminates the result with '\0' so can just use strlen()
but for this example sketch some static rawData will be used as the payload
char rawData[] = "7F22127F22127F22127F22127F221203E0:620101FFF7E71:FF8A00000000832:00240ED71713133:141713000010C14:22C12800008B005:00450B0000434B6:000019A80000187:1200200EE70D018:7B0000000003E8";
char *payload = rawData;
The data has the format headerBytes then one frameNumberByte:frameDataBytes repeated. A : starts each frame of data and the byte just before the : is the frame number.
The results of parsing the frames will be stored in a data struct which has an array of 9 char[20] arrays. cSFA( ) will be used to wrap the each array to store the results.
struct dataFrames_struct {
char frames[9][20]; // 9 frames each of 20chars
typedef struct dataFrames_struct dataFrames; // create a simple name for this type of data
dataFrames results; // this struct will hold the results
The void processPayload(char *OBDdata, size_t datalen, dataFrames & results) method process the input data using cSFP( ) to wrap the OBDdata. The int convertToInt(char* dataFrame, size_t offset, size_t numberBytes) method is a utility method that uses cSFP( ) to wrap the dataFrame pointer setting the SafeString capacity to it current strlen so bytes can be extracted and converted to numbers.
The processing statements are :-
processPayload(payload, results);
printBatteryVolts(results); // plus other data
With the SafeString output set i.e. SafeString::setOutput(Serial); the sketch results are:-
frameIdx:0 SafeString frame cap:19 len:12 '620101FFF7E7'
frameIdx:1 SafeString frame cap:19 len:14 'FF8A0000000083'
frameIdx:2 SafeString frame cap:19 len:14 '00240ED7171313'
frameIdx:3 SafeString frame cap:19 len:14 '141713000010C1'
frameIdx:4 SafeString frame cap:19 len:14 '22C12800008B00'
frameIdx:5 SafeString frame cap:19 len:14 '00450B0000434B'
frameIdx:6 SafeString frame cap:19 len:14 '000019A8000018'
frameIdx:7 SafeString frame cap:19 len:14 '1200200EE70D01'
frameIdx:8 SafeString frame cap:19 len:14 '7B0000000003E8'
hex number hexSubString cap:14 len:4 '0ED7'
Battery Volts:379.9
Commenting out the // SafeString::setOutput(Serial); gives just
Battery Volts:379.9
Looking at the processPayload( ) method
void processPayload(char *OBDdata, dataFrames & results) {
cSFP(data, OBDdata); // wrap in a SafeString, use strlen(OBDdata) to set the capacity
clearResultFrames(results);
size_t idx = data.indexOf(':'); // skip over header and find first delimiter
while (idx >= 0) {
int frameIdx = data[idx - 1] - '0'; // the char before :
if ((frameIdx < 0) || (frameIdx > 8)) { // error in frame number skip this frame, print a message here
SafeString::Output.print("frameIdx:"); SafeString::Output.print(frameIdx); SafeString::Output.print(" outside range data: "); data.debug();
idx = data.indexOf(':', idx + 1); // step over : and find next :
continue;
cSFA(frame, results.frames[frameIdx]); // wrap a result frame in a SafeString to store this frame's data
idx++; // step over :
int nextIdx = data.indexOf(':', idx); // find next : -1 if not found
if (nextIdx > 0) {
data.substring(frame, idx, nextIdx - 1); // next : found so take chars upto 1 char before next :
} else {
data.substring(frame, idx, nextIdx); // next : not found so take all the remaining chars as this field
SafeString::Output.print("frameIdx:"); SafeString::Output.print(frameIdx); SafeString::Output.print(" "); frame.debug();
idx = nextIdx; // step onto next frame
The input data is wrapped for processing. The ELMduino terminates the
OBDdata received data with a terminating '\0', so we can just wrap using createSaftStringFromPtr() ( cSFP() ) which uses strlen(OBDdata) to set the SaftString capacity.
Once the frame number has been found the corresponding char[] in the results struct is wrapped in SafeString using
The frame SafeString is then filled with the field data via
data.substring(frame, idx, nextIdx – 1);
Looking at the convertToInt() method
int convertToInt(char* dataFrame, size_t offset, size_t numberBytes) {
// define a local SafeString on the stack for this method
cSFP(frame, dataFrame);
cSF(hexSubString, frame.capacity()); // allow for taking entire frame as a substring
frame.substring(hexSubString, offset, offset + (numberBytes * 2)); // endIdx in exclusive in SafeString V2
hexSubString.debug(F(" hex number "));
long num = 0;
if (!hexSubString.hexToLong(num)) {
hexSubString.debug(F(" invalid hex number "));
return num;
The input char* dataFrame is wrapped in a SafeString using
As you can see above the frames are not all the same length. cSFP( ) sets the SafeString capacity to the current strlen of the c-string in the dataFrame, so SafeString will detect if you try to access bytes outside the current data and output an error if SafeString::setOutput(Serial); has been called. The SafeString V2 hexToLong() method is used to convert the hex bytes to a number and will output a message if the bytes are not valid hex.
Step 6: Using SafeStrings for Class Variables
You cannot create SafeStrings inside a C++ class. For example
class Loco {
public:
// Members
createSafeString(_niceName, 12);
createSafeString(_locoName, 12);
int _locoAddress;
Will give compile errors like
libraries/SafeString/src/SafeString.h:209:94: error: expected identifier before 'sizeof'
Instead you use char[]'s in the class and then wrap them in SafeString for processing.
class Loco {
private:
// make these private to protect from external access
char _niceName[12];
char _locoName[12];
int _locoAddress;
public:
// Members
Loco(const char* niceName, const char* locoName, int locoAddress);
void printData(Stream& out);
Loco::Loco(const char* niceName, const char* locoName, int locoAddress) {
cSFA(sfNiceName, _niceName); //wrap in SafeStrings for processing
cSFA(sfLocoName, _locoName);
sfNiceName = niceName;
sfLocoName = locoName;
_locoAddress = locoAddress;
void Loco::printData(Stream &out) {
out.print(" niceName:"); out.println((char*)_niceName);
out.print(" locoName:"); out.println((char*)_locoName);
out.print(" location:"); out.println(_locoAddress);
So when you want to work with the char _niceName[] array, you first wrap it in a SafeString using createSafeStringFromArray(sfNiceName, _niceName); OR cSFA(sfNiceName, _niceName); for short.
Then any changes you make to the SafeString sfNiceName are reflected and saved in the char[] _niceName. Notice that cSFA(sfNiceName, _niceName); automatically picks up the valid length of the char _niceName[12]; That is capacity for 11 chars plus a terminating '\0'.
If you try to create a Loco object with a niceName that is too long. SafeString will ignore it and leave the _niceName at an empty c-string. So if you see empty fields for Loco move the construction into the setup() AFTER calling SafeString::setOutput(Serial); to see the error messages. The example sketch SafeStringsInClasses_1.ino shows the locoBad instance temporarily moved into the setup() to show the error messages.
Good C++ class design should protect its data from uncontrolled external changes. So if you need to update _niceName is should be done via a Loco class method. e.g.
void Loco::setNiceName(const char* newNiceName) {
cSFA(sfNiceName,_niceName); // wrap in a SafeString
sfNiceName = newNiceName; // update _niceName, checking it will fit and copying
OR
void Loco::setNiceName(SafeString& sfNewNiceName) {
sfNiceName = sfNewNiceName; // update _niceName, checking it will fit and copying
Also since the char[]s are private in the Loco class, you will need methods to access them. While you could write a method like
const char* Loco::getNiceName() {
return (const char*)_niceName;
this would expose the char _niceName[12] to corruption by external code.
A better method would be
void Loco::getNiceName(SafeString& result) {
result = _niceName; // copy current contents of _niceName into external SafeString
which gives the external code a copy that can be modified without changing the of the interval value.
Step 7: Working With Arrays and Structs of C-strings
If you have an array of c-strings i.e.
#define MAX_STRING_SIZE 40
char arr[][MAX_STRING_SIZE] = {
"array of c string",
"is fun to use",
"make sure to properly",
"tell the array size"
You can easily and safely work with them by wrapping the elements in SafeStrings as needed. i.e.
createSafeStringFromCharArray(sfarr0, arr[0]); // or cSFA(sfarr0, arr[0]); for short
The SafeString sfarr0 automatically knows the maximum capacity of arr[0] and will not let you exceed it. When you modify the SafeString, sfarr0, the underlying arr[0] c-string is updated.
See the sketch SafeStringWithArraysofCstring.ino for a working example.
Using SafeString for structs containing char[] is similar
struct {
char buffer_0[3];
char buffer_1[10] = "test";
char buffer_2[8];
} buffers;
createSafeStringFromCharArray(sfBuffer_0, buffers.buffer_0); // or cSFA(sfBuffer_0, buffers.buffer_0); for short
sfBuffer_0 will now use buffers.buffer_0 as it backing char[] and any changes made to sfBuffer_0 will update the struct. If the buffer_0 memory has garbage in it, SafeString may complain about an untermiated string, but it will clean up the memory to put a '\0' at the end of buffer_0, i.e. in buffer_0[2], to make it valid.
SafeString automatically picks up the sizes of the buffers_.. and sets the maximum capacity of the SafeString to suit.
createSafeStringFromCharArray(sfBuffer_1, buffers.buffer_1); // or cSFA(sfBuffer_1, buffers.buffer_1); for short
Will wrap buffers.buffer_1 including the existing text. The sfBuffer_1 will have a capacity of 9 chars + the terminating '\0' and will initially contain the string 'test'
Step 8: Mixing SafeString and C-string Methods
Because the createSafeStringFrom..() macros wrap existing c-string data, it is possible, but not advisable, to intermix calls to SafeString methods and unsafe c-string methods, like strcat( ). However typically you would do all your processing using SafeString methods, either in a method or within a code block { }
convertToInt() and processPayload() above are examples of doing all the processing with SafeStrings within a method. If you just have little processing to do you can do it in a small block e.g.
Serial.println(str); // => initial data
cSFP(sfStr,str); // wrap in a local SafeString for a bit of processing.
sfStr.replace("data","d"); // can reduce str length just cannot increase it
However if you do intermix SafeString method calls with c-string methods, the wrapped SafeStrings remain valid.
Before executing each method of a wrapped SafeString:-
a) the underlying c-string is re-terminate to the SafeString capacity() and
b) the strlen called to resynchronize the SafeString length to length of the underlying c-string.
Once a SafeString has been created its capacity cannot be changed. It has static size. So even if the c-string pointed to has extra space and more characters are added later, the SafeString will truncate the string to the SafeString's original capacity to prevent possible memory overruns. SafeString also resynchronizes its length to the current strlen( ) to allow for external changes.
For example
char testData[50] = "initial data"; // space for more chars here
char* str = testData;
Serial.print(F("str => "));Serial.println(str);
cSFP(sfStr, str); // create from a char* capacity is set to initial strlen
sfStr.debug(F("Initial cSFP( ) contents :"));
strcat(testData, "123"); // access the c-string, str, directly
sfStr.debug(F("After strcat :")); // no change is capacity
Serial.print(F("str => "));Serial.println(str); // underlying str was reterminated at capacity
str[7] = 0; // truncate underlying str
sfStr.debug(F("After str[7] = 0")); // new length picked up
Produces the output the following output. Note how the strcat of "123" is lost when the sfStr SafeString re-terminates the underlying c-string to the original capacity. But the new string length after str[7] = 0; is picked up.
str => initial data
Initial cSFP( ) contents : sfStr cap:12 len:12 'initial data'
After strcat : sfStr cap:12 len:12 'initial data'
str => initial data
After str[7] = 0 sfStr cap:12 len:7 'initial'
str => initial
So after performing c-string operations on the underlying char *, SafeStrings remain safe, but it intermix c-string methods and SafeString methods is not advised as the results may not be what you expect.
Also see the SafeStringFromCharArray.ino, SafeStringFromCharPtr.ino and SafeStringFromCharPtrWithSize.ino example sketches included with the SafeString library V2.
Memory Usage versus Processing Time
A final point on the createSafeStringFrom...() macros. As discussed above each time a SafeString method is called on a SafeString created with one of these macros, the current length of the underlying char[] is checked using strlen( ) and the SafeString.length() updated. This picks up any changes made directly on the underlying char[]. The more times methods are called and the larger the underlying c-string is the more processing time this takes. You can trade this processing cost for memory usage by creating a local SafeString, using createSafeString() or cSF() and copying the data to it. e.g. instead of
cSFP(data, OBDdata); // wrap in a SafeString<br> ....
use
cSF(data, strlen(OBDdata)); // create a local SafeString large enough to hold the incoming data
data = OBDdata; // copy the OBDdata to the SafeString, = does a copy<br> . . . .
Then calling methods on the data SafeString created using cSF( ), do not call strlen( ), because only the SafeString has access to the data. This saves processing time at the expense of the extra stack space used for the data char[] the cSF() macro adds. Also any changes made via the cSF() SafeString methods do not effect the input OBDdata.
Step 9: Method 'static' SafeStrings and ReadFrom() and WriteTo()
The example sketch SafeString_ReadFrom_WriteTo.ino (included with the SafeString library), illustrates creating method 'static' SafeStrings which keep their value across method calls. That example also covers the readFrom() and writeTo() SafeString methods. SafeString V2 removes readBuffer(),writeBuffer() and adds the safer readFrom(), writeTo() methods.
Method 'static' SafeStrings are created by wrapping 'static' char[]. e.g.
size_t processInput(char* text, size_t txtIdx, char* outBuf, size_t outBufSize ) {
// these two method static's keep their values between method calls
static char inputArray[MAX_CMD_LENGTH + 2]; // +1 for delimiter, +1 for terminating '\0' keep this array from call to call
static char tokenArray[MAX_CMD_LENGTH + 2]; // +1 for delimiter, +1 for terminating '\0' keep this array from call to call
cSFA(input, inputArray); // create a 'static' SafeString string by wrapping the static array inputArray
cSFA(token, tokenArray); // create a 'static' SafeString string by wrapping the static array tokenArray
The rest of the example covers reading small parts of large buffer into the input SafeString, via readFrom(), to parse valid commands. Any valid command found is then written to a very small output buffer, via writeTo(). The output buffer is very slowly printed out. As space becomes available in the output buffer the rest of the command is written to it. All of this processing is non-blocking. The loop() code continues to run at maximum speed.
See Arduino Serial I/O for the Real World for a simpler method of reading input
Step 10: A String Tokenising and Number Conversion Example
The SafeString_stoken_Example.ino sketch illustrates extracting numbers from a CSV (comma separated values) input and converting the valid fields to numbers. Also see the SafeString_stoken example included with the SafeString library Commenting out the
to remove all the SafeString::Output.print( ) and debug( ) output gives the following
The input is 23.5, 44a ,, , -5. , +.5, 7a, 33,fred5, 6.5.3, a.5,b.3<br><br>Fields with numbers are:-
Field 1 : 23.50
Field 5 : -5.00
Field 6 : 0.50
Field 8 : 33.00
Note that after finding and processing one field the rest of the loop() is run, so the rest of you program remains 'alive'. If you where using the Arduino String class there would be two problems, i) there is no tokenize method and ii) fields like 44a would be interpreted as valid numeric fields.
Step 11: User Commands Example
See Arduino Serial I/O for the Real World for a detailed tutorial on handling Serial I/O without blocking the rest of your sketch.
SafeString V3 includes the SafeStringReader class that simplifies reading delimited tokens from Streams. SafeStringReader wraps up the SafeString readUntilToken() method and its supporting variables. The examples SafeStringReader_Cmds.ino and SafeStringReader_CmdsTimed.ino illustrate reading user commands.
You often need a way to enter commands to control a sketch, while it is running. The standard Arduino Stream methods, readString(), readStringUntil(), etc, do not support this because they pause the whole program while waiting for the user input. They are completely unsuitable when the rest of the sketch is controlling something in 'real time', e.g. a stepper motor.
The basic user commands sketch is simply:-
createSafeStringReader(sfReader, 5, " ,\r\n"); // create the SafeStringReader sfReader and its supporting buffers
// to handle cmds upto 5 chars long delimited by space, comma, Carrage return or Newline
void setup() {
Serial.begin(9600);
for (int i = 10; i > 0; i--) { // pause a little to give you time to open the Arduino monitor
Serial.print(i); Serial.print(' '); delay(500);
Serial.println();
SafeString::setOutput(Serial); // enable error messages and SafeString.debug() output to be sent to Serial
sfReader.connect(Serial); // where SafeStringReader will read from
sfReader.echoOn(); // echo back all input, by default echo is off
// sfReader.setTimeout(2000); // optionally set a non-blocking read timeout
void handleStartCmd() {
// handle start cmd here
void handleStopCmd() {
// handle stop cmd here
void loop() {
if (sfReader.read()) {
if (sfReader == "start") {
handleStartCmd();
} else if (sfReader == "stop") {
handleStopCmd();
} // else ignore unrecognized command
} // else no delimited command yet
// rest of code here is executed while the user typing in commands
The process is, read some input until a delimiter is found, check
the token against known commands then execute rest of the loop code, and repeat. There are no delays waiting for user input in this process, so the loop() runs at maximum speed. Although this sketch will accept an unlimited number of input characters and commands in one line, the size of the input and token SafeStrings need only be 1 more then the longest command (to allow for the delimiter), so the sketch uses very little RAM memory. If the Arduino monitor is set to No line ending, or the input is being sent character by character from a terminal program, then an optional non-blocking timeout can be set to automatically terminate the last command after chars stop coming
For most use cases the SafeStringReader is all that is needed. However the SafeString class itself also has three supporting non-blocking read methods, read( stream ), readUntil( stream, .. ) and readUntilToken( stream, … ), if you need more flexiabilty than the SafeStringReader provides.
Step 12: Converting Between String and SafeString
To convert an Arduino (C++) String to a SafeString, create as SafeString of sufficient size and copy the String to the SafeString.
String arduinoStr("this is a string");
Serial.print(" Arduino String : "); Serial.println(arduinoStr);
createSafeString(sfStr, arduinoStr.length()); // create a SafeString of sufficient size
sfStr = arduinoStr.c_str(); // copy arduinoStr to the SafeString
sfStr.debug();
This gives the output, (if SafeString::setOutput(Serial); has been called)
Arduino String : this is a string
SafeString sfStr cap:16 len:16 'this is a string'
To convert from a SafeString back to an Arduino (C++) String just use
arduinoStr = str.c_str();
Step 13: Differences Between Arduino Strings (WString.cpp) and SafeStrings
The major difference is that the capacity of a SafeString is fixed at creation and does not change, where as Arduino Strings can resize dynamically using more memory then you expected and fragmenting the heap-space. SafeStrings are also more robust and provide detailed error messages when an operation cannot be preformed.
SafeStrings are Always Valid
SafeString is always left unchanged and in a valid state even if the operation cannot be preformed. On the other hand, Arduino Strings loose all the existing data if the dynamic resize fails and some operations result in invalid String states. e.g.
String str = "abc";
str += '\0';
or
str[2] = '\0';
result in an invalid Arduino String.
In SafeString, s_str += '\0'; and s_str.concat('\0'); errors are caught and ignored and generate an error message. While str[ .. ] = is not supported because the error cannot be caught. In SafeStrings use setCharAt( ) instead.
str.setCharAt(2,'a');
SafeStrings provide consistent operator syntax
SafeStrings do not support the + operator, because it creates temporary Strings objects and is problematic in its application. For example
String testStr1;
testStr1 = "a" + 10; // this compiles and runs
testStr1 = "a" + 10 + "b"; // this does NOT compile
With SafeStrings use the += operator or the concat() method, i.e.
createSafeString(testStr, 20);
testStr = "a";
testStr += 10;
testStr += "b";
SafeStrings have Non-blocking Read methods
SafeStrings has three non-blocking read methods, readUntilToken(), readUntil() and read() which allow you to look for user input without halting the rest of your program. See the User Commands Example above. The SafeString library also includes the BufferedOutput class that provides non-blocking print() and write() methods. Together they provide practical non-blocking replacement for the Arduino Serial blocking class. See Arduino Serial I/O for the Real World
SafeStrings have stoken( ) and nextToken() methods
SafeString has two tokenising methods. stoken() is the low level method which can be used to split a string into tokens separated by specified delimiters or extract tokens that only contain characters from a specified valid set of characters. nextToken() is a high level method that will remove a delimited token from the SafeString and and return it for processing. See the User Commands Example above and the SafeString_stoken example sketch provided with the library.
SafeStrings implement the Print interface
As shown in the previous examples, SafeStrings implement the Print interface so you can print( ) to a SafeString to add text to it and use all the familiar formatting features available with print( ).
Differences in string to number conversions
There are noticeable differences between SafeStrings and Arduino Strings for string to number conversions. In Arduino Strings, if the conversion fails the method returns 0 or 0.0 , so you cannot tell if the conversion failed or the number was actually 0 Also the Arduino String number conversions do not look at the whole string but just stop and return a result as soon as the next character is invalid. For example for Arduino String toInt() on “5a” returns 5 as the answer, and for toFloat(), “5.3.5” returns 5.3.
The SafeStrings conversion methods, on the other hand, return true or false to indicate if a valid number was found and if one is found then the argument variable is updated. For example (also see the SafeStringToNum example sketch provided with the library.)
createSafeString(str, 7, " 5.3.6 ");
float f = 0.0;
bool rtn = str.toFloat(f);
will return false and leave f unchanged
createSafeString(str, 7, " 5 ");
long ans = 0;
bool rtn = str.toLong(ans);
will return true and set ans to 5.
Arduino String's toInt() method actually converts the string to a long
Step 14: SafeString Error Flags and Controlling SafeString Error Messages and Debugging
SafeString has extensive error checking built-in. SafeString also has error flags your program can check, even if error messages are turned off.
SafeString has a global error flag which is set whenever an error is detected in any SafeString.
SafeString::errorDetected() will return true in there has been any errors since the last time this method was called. The global error flag is cleared each time errorDetected() is called.
Each SafeString object has its own private error flag and calling hasError() on a SafeString object will return true if there has been any error detected on that SafeString since the last call to hasError(). e.g.
cSF(sfStr,5);
sfStr = "abcdeft";
if (sfStr.hasError()) {
Serial.println(F("Error detected on sfStr"));
Detecting Errors is Global SafeStrings
Global SafeStrings are setup before the sketch starts running, so you cannot print out error messages for them. However you can check if there are any errors by checking SafeString::errorDetected() in the setup().
void setup() {
Serial.begin(9600);
SafeString::setOutput(Serial); // for error msgs
if (SafeString::errorDetected()) {
Serial.println(F("Error setting up global SafeStrings"));
To enable the error messages, you need to tell SafeString where to send them to using the setOutput( ) method
Then if your code tries to exceed the capacity of a SafeString, you will get an error message sent to Serial e.g.
stringOne = "abc";
stringOne += "123456789";
Error: stringOne.concat() needs capacity of 12 for the first 9 chars of the input.
Input arg was '123456789'
stringOne cap:8 len:3 'abc'
The error message tells you which operation failed, why it failed and a summary of the current state of the SafeString object and it current contents. This is enough for you to find and fix the problem. In this case by increasing the size of stringOne to 12 in the createSafeString( ) macro.
You can use the setVerbose( ) method to turn off/on the printing of the current string contents in error messages at various points in your sketch.
SafeString::setVerbose(false);
stringOne = "abc";
now outputs a more compact error message.
Error: stringOne.concat() needs capacity of 12 for the first 9 chars of the input. --- stringOne cap:8 len:3
SafeString Debug statements
You often want to debug your program by outputting the value of a SafeString at various points in the program. The debug() method does that for you. Once you have told SafeString where to send error/debugging messages, you can use the debug( ) method to output the current state of a SafeString. e.g.
stringOne.debug();
SafeString stringOne cap:8 len:3 'abc'
To get a compact output without the string's contents use
stringOne.debug(false);
You can also add a title, either a " ... " or an F( ) string or another SafeString, to the debug output e.g.
stringOne.debug(F(" After stringOne = \"abc\";") );
After stringOne = "abc"; stringOne cap:8 len:3 'abc'
Turning off SafeString Error messages and debug output
You can use the statement
SafeString::turnOutputOff();
to turn off all error messages and debug() output from then on. Use
to turn it back on again.
Using SafeString::Output for debugging messages
You can print debugging messages using SafeString's Output. e.g.
SafeString::Output.println(" string debug msg.. ");
If SafeString::setOutput( ) has been called then SafeString::Output.print( will print to that Stream. Otherwise the output is discarded. This lets you add string debugging messages that will disappear when you turn off the other SafeString error messages and debugging output.
Removing All Error Messages Code
The SafeString Error messages add a noticeable amount of code to your program. If you are running out of program space, you can quickly remove all the error messages code by commenting out
// #define SSTRING_DEBUG
at the top of the SafeString.h file and recompiling your sketch. This will remove all the error message handling but will keep all the error checks so that your code is still safe and robust.
The debug() method and SafeString::Output.print( methods are still available with //#define SSTRING_DEBUG commented out, but the name of the variable is not longer included in the debug() output. i.e.
After stringOne = "abc"; cap:8 len:3 'abc'
Debug and Error Message Print Delays
Sending output to Serial can delay the rest of you program from running. At 9600baud it takes about 1mS per char to send the output. Once the outgoing Serial buffer fills up, your program stops and waits for some chars to be sent to free up space in the buffer so it can send the rest of the output. See Arduino Serial I/O for the Real World for how to over come this.
You can also reduce the amount of SafeString output by using setVerbose(false); This gives compact error messages which omit the printing the contents of the SafeString. debug(..,false); does the same for debug() statements.
Step 15: What Is Wrong With Arduino String Processing – Not Much Actually
C-string methods have been the bane of programmers for over 30 years and the cause of so many programming errors and security breaches that Microsoft has banned their programmers from using them (local copy here) and text books have been written on why they should not be used. For example Secure Coding in C and C++, 2nd Edition by Robert C. Seacord, Ch5 (local copy here) which discusses the dangers of particular c-string methods and Ch2 (local copy here) which talks about how easy it is to get coding errors. Low level operations on char[]s, a char at a time, are also a major source of errors. Hackers love the use c-string methods and char[] code as it allows them to force buffer overflows and gain access to computer systems. See the Wikipedia Buffer_overflow entry and for just the latest example of a commercial coding error using c-strings and char[] operations, see the 'bug' in Unix's sudo code. The lastest IPhone security failing is another recent example.
Both Sparkfun and Adafruit advise against using the Arduino String class. Sparkfun's comment on the String class is “The String method (capital 'S') in Arduino uses a large amount of memory and tends to cause problems in larger scale projects. ‘S’trings should be strongly avoided in libraries.
Adafruit's comment on the String class is “In most usages, lots of other little String objects are used temporarily as you perform these (String) operations, forcing the new string allocation to a new area of the heap and leaving a big hole where the previous one was (memory fragmentation). “
However as the tutorial on Taming Arduino Strings shows you can avoid the memory fragmentation and excessive memory usage, by following a few simple guidelines. And the good news is that on Uno and Mega2560 using Arduino Strings is extremely safe and robust, even if you run out-of-memory. If you run out-of-memory, you will just not get all the text in the Strings that you expect. The program will continue to run. See What happens when UNO runs out of heap memory in the Taming Arduino Strings tutorial
Some of the Errors in Arduino's WString code
The current WString code supplied with Arduino contains a number of bugs which cause programs using it to either fail or give un-expected results. For example
String a;
a = "12345";
Serial.println(a);
a += a;
Serial.println(a);
causes an Arduino UNO to continually reboot.
Another example is
String aStr;<br> aStr = "";
aStr.concat('\0');
Serial.print("aStr .length():");Serial.println(aStr .length());
Serial.print("strlen(aStr.c_str()):");Serial.println(strlen(aStr .c_str()));
which outputs
aStr.length():1<br>strlen(aStr.c_str()):0
That is the String object length() is no longer the same as the strlen() of the underlying char buffer. The Arduino String class has a number of these types of errors.
In contrast using SafeStrings gives outputs of for the first example
12345<br>1234512345
And for the second example gives the error message
Error: aStr.concat() of '\0'
Using SafeStrings, the first example works as expected and the second example gives a detailed error message contain the name of the SafeString, aStr, involved, and leaves the original value of aStr unchanged. Most, but not all of, WString's bugs could be fixed but that would not fix the basic problems with Arduino Strings dynamic memory allocation and lots of object creations and data copying.
In number conversion, Arduino String.toInt() can give odd errors. For example
String a_str("123456789012345");
Serial.println(a_str.toInt());
Outputs
-2045911175
While SafeString toLong(num) returns false indicating the string is not a valid long and the num argument is unchanged. See the SafeStringToNum example sketch provided with the library.
Step 16: Conclusion
String processing using low level C character arrays (using strcat, srtcpy etc) is a major source of program crashes and is not recommended. While the Arduino Strings are very usable and safe if you follow the guidelines, if you want to keep complete control over your memory usage or you are working with a library that returns a char* or you want a richer set of readers, parsers and text functions and a library that provides detailed debug error messages, then SafeStrings are preferred.
The SafeString library provide numerous examples and as well as simple practical sketch which process user commands while keeping running the sketch at maximum speed
Arduino Contest 2020
