Introduction: Arduino and PIR Sensor Interface
Hi friends, today in this instructables I am going to tell you, how to use a PIR Motion sensor with Arduino. You can use this as a security system at night. So, lets makethis project !!!
Step 1: Components Needed
1.) Arduino UNO
2.) PIR Motion sensor
3.) USB B Type cable
4.) Laptop with Arduino IDE installed
5.) Some wires
6.) Breadboard
7.) LED
Step 2: The Schematic
Step 3: The Code
Copy the following code and upload it in your Arduino.
//VARS //the time we give the sensor to calibrate (10-60 secs according to the datasheet) int calibrationTime = 30;
//the time when the sensor outputs a low impulse long unsigned int lowIn;
//the amount of milliseconds the sensor has to be low //before we assume all motion has stopped long unsigned int pause = 5000;
boolean lockLow = true; boolean takeLowTime;
int pirPin = 2; //the digital pin connected to the PIR sensor's output int ledPin = 8;
///////////////////////////// //SETUP void setup(){ Serial.begin(9600); pinMode(pirPin, INPUT); pinMode(ledPin, OUTPUT); digitalWrite(pirPin, LOW);
//give the sensor some time to calibrate Serial.print("calibrating sensor "); for(int i = 0; i < calibrationTime; i++){ Serial.print("."); delay(1000); } Serial.println(" done"); Serial.println("SENSOR ACTIVE"); delay(50); }
//////////////////////////// //LOOP void loop(){
if(digitalRead(pirPin) == HIGH){ digitalWrite(ledPin, HIGH); //the led visualizes the sensors output pin state if(lockLow){ //makes sure we wait for a transition to LOW before any further output is made: lockLow = false; Serial.println("---"); Serial.print("motion detected at "); Serial.print(millis()/1000); Serial.println(" sec"); delay(50); } takeLowTime = true; }
if(digitalRead(pirPin) == LOW){ digitalWrite(ledPin, LOW); //the led visualizes the sensors output pin state
if(takeLowTime){ lowIn = millis(); //save the time of the transition from high to LOW takeLowTime = false; //make sure this is only done at the start of a LOW phase } //if the sensor is low for more than the given pause, //we assume that no more motion is going to happen if(!lockLow && millis() - lowIn > pause){ //makes sure this block of code is only executed again after //a new motion sequence has been detected lockLow = true; Serial.print("motion ended at "); //output Serial.print((millis() - pause)/1000); Serial.println(" sec"); delay(50); } } }
Step 4: Implementation
You can install this system at your home so that you can know that something or somebody is moving. You can also use it during Halloween to scare people. This system can also be used to power the lights. This can help you in walking downstairs during night.
