Introduction: Mini Project #3: DIY Paracord Dispenser
Hi Instructables community,
on day three of this weeks Mini Projects I'm showing you a little life hack to organize your paracord if you are not using spools.
I use this method mostly to organize pieces of paracord of a few meters/yards length that are left over from other projects.
With this method you will have quick access to your cord whilst avoiding tangling and knots.
If you like this Instructable please fav, share, subscribe & comment. You can also check my YouTube, Facebook and Twitter sites for current and upcoming projects.
Take care & stay safe
Cheers Alex
Step 1: What Do You Need?
You will need the following materials:
- An empty plastic bottle (e.g. from a fruit smoothie) with a screw-on bottle cap - This size depends on the length of the cord you want to store in it.
- Paracord/550 Cord leftovers
And tools:
- A hammer or drill
- A 6mm (1/4 Inch) hole punch - Or equivalent drill bit
- A work surface (e.g. wooden cutoff)
Step 2: Punch the Hole
Place the bottle cap on your work surface and place the hole punch in the center. Use your hammer to punch a hole through the cap.
Step 3: Filling the Bottle
Insert one end of the paracord into the hole in the lid. Continue to feed in the cord and shake the bottle every now and then to fill gaps. Once you are finished tie a simple knot in the end to prevent the cord from slipping into the bottle.
Step 4: You Are Done
You can now pull out cord when you need some and if you are using a clear bottle you will be able to see how much cord is left. If you use the type of bottle cap as shown in the video you will have a waterproof paracord container for outdoor use.
Happy making.
Epilog Contest VII
Survival Contest
