Introduction: ElectronicsLovers ZERO-IoT-Development Board – ZID-2020
About: Electronicslovers started in July 2011 with the mission to produce ideas to student and engineer or hobbyist to learn electronics practically. Electronicslovers provides information by publishing tutorial, ele…
Introduction:
These days, time is money, and we all need to find the quickest way to get what we need, be it a product, a service, or an outcome. One way to save time on projects is to use a ‘development board’. Development boards help save up time consumed in the basic setup of your projects.
What is a development board?
Board V2.0 3D view A development board is simply a printed circuit board which comes with pre-installed circuitry and hardware. These boards help to save time when you are repeatedly working on a type of microcontroller. And so, instead of setting up the circuitry and hardware on a breadboard every time you simply work with a development board that comes with everything set up beforehand. This is particularly useful if you’re using a microcontroller for general repetitive experimentation and prototyping.
There is also the chance of errors if you’re building a basic setup yourself every time with a breadboard since you could mess up the connections, and so in the case of errors in your project, it is difficult to identify if the error is due to your setup or the programming. And so, debugging will consume even more time. This is why it is better to use a development board, plus you can use development boards in multiple projects, it is a one-time investment that surely pays off.
Step 1: ZERO-IoT-Development Board – ZID-2020-V1.0:
Electronicslovers recently designed a New Development Board version 1.0 called “ZERO-IOT-DEVELOPMENT BOARD” for Students and Tech Lovers, it has based on the Internet of things (IoT).
You can use ZID-2020 to make projects related to automation, security, and all types of smart home applications. JLCPCB has sponsored all the electronic components and the PCBs for this development board.
Good luck! You can create multiple projects by using our new development board. The IoT domain is ever-increasing in popularity and demand. With development boards, you will find ease in your capability to create new projects. What projects are you most interested in making first?
Step 2: PCB Package Unboxing of ElectronicsLovers ZERO-IoT-Development Board Video
Step 3: LCSC Has Sponsored All the Electronic Components for ZID Board-2020
JLCPCB also has its counterpart, LCSC, which is more focused around the distribution of electronic components. Located in Shenzhen and founded in 2011, now catering to over 900,000 customers worldwide. It has a wide range of products for you to choose from including semiconductors, resistors, capacitors, diodes, inductors, connectors, transistors and sensors etc.
Step 4: ElectronicsLovers ZERO-IoT-Development Board – ZID-2020 Assembling:
Step 5: ElectronicsLovers ZERO-IoT-Development Board V1.0 Video
Step 6: ElectronicsLovers ZERO-IoT-Development Board V2.0 3D View
For Gerber File and PCB Cooperation Contact Us
THIS DESIGN AND PROJECT IS “”© COPYRIGHTED “” BY ELECTRONICSLOVERS – Do not Sell or Share without the Authorization of Electronicslovers.
Thank you JLCPCB
JLCPCB aka JiaLiChuang Co., Limited based in Hong Kong is a PCB manufacturing company that deals in high-quality PCB prototypes and small-batch PCBs at an extremely cost-effective rate. They have been working in this field for over 14 years and now claim to have over 800,000 customers worldwide.
