Introduction: Emotion Shirt Using a Linkit One
My family loves the movie Inside Out. So I thought it would be great if I made a shirt that would show emotions. I decided the Linkit One would be perfect for this as it would give you wireless access to the controls
Step 1: Tools/Materials
Tools
- Computer
- USB cable
- Soldering Iron
- Wire Cutters
- Needle
- Scissors
- Wire Strippers
- Helping Hands
Materials
- Linkit One
- Battery for Linkit One
- Wifi Cable for Linkit One
- 3 - RGB LED (common anode)
- 1 - Circular Circuit Board
- 1- Breadboard
- 1- Wires (Most of my wires were scavenged from old computers)
- Solder
- 1- Shirt
- Thread
- Extra Fabric
- Super Glue
- 1 - Half a small plastic sphere about the size of the circular circuit board (I got mine from a quarter machine)
- Poly-fil
- Two Part Putty Epoxy (Water Weld)
Step 2: Code
This code is designed to light up certain colors of the RGB LED. It is set up in such a way that you can activate the color that corresponds with the colors of the emotions in Inside Out.
<p>//#include <b64.h><br>#include <httpclient.h> #include <ltask.h> #include <lwifi.h> #include <lwificlient.h> #include <ldatetime.h> #define WIFI_AP "" #define WIFI_PASSWORD "" #define WIFI_AUTH LWIFI_WPA // choose from LWIFI_OPEN, LWIFI_WPA, or LWIFI_WEP. #define per 50 #define per1 3 #define DEVICEID "" // Input your deviceId #define DEVICEKEY "" // Input your deviceKey #define SITE_URL "api.mediatek.com"</ldatetime.h></lwificlient.h></lwifi.h></ltask.h></httpclient.h></b64.h></p><p>LWiFiClient c; unsigned int rtc; unsigned int lrtc; unsigned int rtc1; unsigned int lrtc1; char port[4]={0}; char connection_info[21]={0}; char ip[21]={0}; int portnum; int val = 0; String tcpdata = String(DEVICEID) + "," + String(DEVICEKEY) + ",0"; String upload_led; String tcpcmd_ledJoy_on = "LED_ControlJoy,1"; String tcpcmd_ledJoy_off = "LED_ControlJoy,0";</p><p>String tcpcmd_ledAnger_on = "LED_ControlAnger,1"; String tcpcmd_ledAnger_off = "LED_ControlAnger,0";</p><p>String tcpcmd_ledDisgust_on = "LED_ControlDisgust,1"; String tcpcmd_ledDisgust_off = "LED_ControlDisgust,0";</p><p>String tcpcmd_ledFear_on = "LED_ControlFear,1"; String tcpcmd_ledFear_off = "LED_ControlFear,0";</p><p>String tcpcmd_ledSad_on = "LED_ControlSad,1"; String tcpcmd_ledSad_off = "LED_ControlSad,0";</p><p>LWiFiClient c2; HttpClient http(c2);</p><p>void setup() { LTask.begin(); LWiFi.begin(); Serial.begin(115200); /*while(!Serial) delay(1000); /* comment out this line when Serial is not present, ie. run this demo without connect to PC */</p><p> Serial.println("Connecting to AP"); while (0 == LWiFi.connect(WIFI_AP, LWiFiLoginInfo(WIFI_AUTH, WIFI_PASSWORD))) { delay(1000); } Serial.println("calling connection");</p><p> while (!c2.connect(SITE_URL, 80)) { Serial.println("Re-Connecting to WebSite"); delay(1000); } delay(100);</p><p> pinMode(13, OUTPUT); pinMode(12, OUTPUT); pinMode(11, OUTPUT); pinMode(10, OUTPUT); pinMode(9, OUTPUT); pinMode(8, OUTPUT); pinMode(7, OUTPUT); pinMode(6, OUTPUT); pinMode(5, OUTPUT); pinMode(4, OUTPUT); pinMode(3, OUTPUT); pinMode(2, OUTPUT); getconnectInfo(); connectTCP(); }</p><p>void getconnectInfo(){ //calling RESTful API to get TCP socket connection c2.print("GET /mcs/v2/devices/"); c2.print(DEVICEID); c2.println("/connections.csv HTTP/1.1"); c2.print("Host: "); c2.println(SITE_URL); c2.print("deviceKey: "); c2.println(DEVICEKEY); c2.println("Connection: close"); c2.println(); delay(500);</p><p> int errorcount = 0; while (!c2.available()) { Serial.println("waiting HTTP response: "); Serial.println(errorcount); errorcount += 1; if (errorcount > 10) { c2.stop(); return; } delay(100); } int err = http.skipResponseHeaders();</p><p> int bodyLen = http.contentLength(); Serial.print("Content length is: "); Serial.println(bodyLen); Serial.println(); char c; int ipcount = 0; int count = 0; int separater = 0; while (c2) { int v = c2.read(); if (v != -1) { c = v; Serial.print(c); connection_info[ipcount]=c; if(c==',') separater=ipcount; ipcount++; } else { Serial.println("no more content, disconnect"); c2.stop();</p><p> } } Serial.print("The connection info: "); Serial.println(connection_info); int i; for(i=0;i<separater;i++) ="" {="" ip[i]="connection_info[i];" }="" int="" j="0;" separater++;="" for(i="separater;i<21" &&="" j<5;i++)="" port[j]="connection_info[i];" j++;="" serial.println("the="" tcp="" socket="" connection="" instructions:");="" serial.print("ip:="" ");="" serial.println(ip);="" serial.print("port:="" serial.println(port);="" portnum="atoi" (port);="" serial.println(portnum);<="" p=""></separater;i++)></p><p>} //getconnectInfo</p><p>void uploadstatus(){ //calling RESTful API to upload datapoint to MCS to report LED status Serial.println("calling connection"); LWiFiClient c2; </p><p> while (!c2.connect(SITE_URL, 80)) { Serial.println("Re-Connecting to WebSite"); delay(1000); } delay(100); if(digitalRead(13)==1) upload_led = "LED_Display,,1"; else upload_led = "LED_Display,,0"; int thislength = upload_led.length(); HttpClient http(c2); c2.print("POST /mcs/v2/devices/"); c2.print(DEVICEID); c2.println("/datapoints.csv HTTP/1.1"); c2.print("Host: "); c2.println(SITE_URL); c2.print("deviceKey: "); c2.println(DEVICEKEY); c2.print("Content-Length: "); c2.println(thislength); c2.println("Content-Type: text/csv"); c2.println("Connection: close"); c2.println(); c2.println(upload_led); delay(500);</p><p> int errorcount = 0; while (!c2.available()) { Serial.print("waiting HTTP response: "); Serial.println(errorcount); errorcount += 1; if (errorcount > 10) { c2.stop(); return; } delay(100); } int err = http.skipResponseHeaders();</p><p> int bodyLen = http.contentLength(); Serial.print("Content length is: "); Serial.println(bodyLen); Serial.println(); while (c2) { int v = c2.read(); if (v != -1) { Serial.print(char(v)); } else { Serial.println("no more content, disconnect"); c2.stop();</p><p> } } }</p><p>void connectTCP(){ //establish TCP connection with TCP Server with designate IP and Port c.stop(); Serial.println("Connecting to TCP"); Serial.println(ip); Serial.println(portnum); while (0 == c.connect(ip, portnum)) { Serial.println("Re-Connecting to TCP"); delay(1000); } Serial.println("send TCP connect"); c.println(tcpdata); c.println(); Serial.println("waiting TCP response:"); } //connectTCP</p><p>void heartBeat(){ Serial.println("send TCP heartBeat"); c.println(tcpdata); c.println(); } //heartBeat</p><p>void loop() //Red led { //Check for TCP socket command from MCS Server String tcpcmd=""; while (c.available()) { int v = c.read(); if (v != -1) { Serial.print((char)v); tcpcmd += (char)v; if (tcpcmd.substring(40).equals(tcpcmd_ledAnger_on)){ digitalWrite(4, HIGH); digitalWrite(3, HIGH); digitalWrite(2, HIGH); Serial.print("Switch LED ON "); tcpcmd=""; } else if(tcpcmd.substring(40).equals(tcpcmd_ledAnger_off)){ digitalWrite(4, LOW); digitalWrite(3, LOW); digitalWrite(2, LOW); Serial.print("Switch LED OFF"); tcpcmd=""; } else if(tcpcmd.substring(40).equals(tcpcmd_ledJoy_on)){ digitalWrite(4, HIGH); digitalWrite(3, HIGH); digitalWrite(2, HIGH); digitalWrite(10, HIGH); digitalWrite(9, HIGH); digitalWrite(8, HIGH); digitalWrite(7, HIGH); digitalWrite(6, HIGH); digitalWrite(5, HIGH); Serial.print("Switch LED ON "); tcpcmd=""; } else if(tcpcmd.substring(40).equals(tcpcmd_ledJoy_off)){ digitalWrite(4, LOW); digitalWrite(3, LOW); digitalWrite(2, LOW); digitalWrite(10, LOW); digitalWrite(9, LOW); digitalWrite(8, LOW); digitalWrite(7, LOW); digitalWrite(6, LOW); digitalWrite(5, LOW); Serial.print("Switch LED OFF"); tcpcmd=""; } else if(tcpcmd.substring(40).equals(tcpcmd_ledDisgust_on)){ digitalWrite(10, HIGH); digitalWrite(9, HIGH); digitalWrite(8, HIGH); Serial.print("Switch LED ON "); tcpcmd=""; } else if(tcpcmd.substring(40).equals(tcpcmd_ledDisgust_off)){ digitalWrite(10, LOW); digitalWrite(9, LOW); digitalWrite(8, LOW); Serial.print("Switch LED OFF"); tcpcmd=""; } else if(tcpcmd.substring(40).equals(tcpcmd_ledFear_on)){ digitalWrite(4, HIGH); digitalWrite(3, HIGH); digitalWrite(2, HIGH); digitalWrite(7, HIGH); digitalWrite(6, HIGH); digitalWrite(5, HIGH); Serial.print("Switch LED ON"); tcpcmd=""; } else if(tcpcmd.substring(40).equals(tcpcmd_ledFear_off)){ digitalWrite(4, LOW); digitalWrite(3, LOW); digitalWrite(2, LOW); digitalWrite(7, LOW); digitalWrite(6, LOW); digitalWrite(5, LOW); Serial.print("Switch LED OFF"); tcpcmd=""; }</p><p> else if(tcpcmd.substring(40).equals(tcpcmd_ledSad_on)){ digitalWrite(7, HIGH); digitalWrite(6, HIGH); digitalWrite(5, HIGH); Serial.print("Switch LED ON"); tcpcmd=""; } else if(tcpcmd.substring(40).equals(tcpcmd_ledSad_off)){ digitalWrite(7, LOW); digitalWrite(6, LOW); digitalWrite(5, LOW); Serial.print("Switch LED OFF"); tcpcmd=""; } } }</p><p> LDateTime.getRtc(&rtc); if ((rtc - lrtc) >= per) { heartBeat(); lrtc = rtc; } //Check for report datapoint status interval LDateTime.getRtc(&rtc1); if ((rtc1 - lrtc1) >= per1) { uploadstatus(); lrtc1 = rtc1; } }</p>
Step 3: Testing
After working out my code I needed to test it. I set up three LEDs on my breadboard and wired them to the Linkit One. I wired the red leads of the three LEDs into digital pins 2, 3, and 4. I wired the blue leads of the three LEDs into digital pins 5, 6, and 7. I wired the green leads of the three LEDs into digital pins 8, 9, and 10. Then I wired in the ground from the LEDs to the ground of the board.
Step 4: Making the Light
I bent the ground lead on the RGB LEDs out. I placed the three LEDs in the circle so that the ground leads are near each other. I soldered these three together with the wire for the ground. I trimmed the leads of the LEDs as I soldered wires to them. I soldered the wires to the other leads of the LEDs. I used the left over leads that I cut and soldered them to the other end of the wire to help them fit into the ports of the Linkit One. I used heat shrink tubing to keep the wires together and to protect from shorts. Then I put the wires in the Linkit One in the same pins as I did for the testing step. I used water weld to hold the wires in place. Then I put a small amount of Poly-fil around the LEDs. This helps diffuse the light. Then I put half a small plastic sphere from a cheap plastic toy over the Poly-fil and lights. This gives it a nice rounded look and helps it resemble the memories from the movie Inside Out. I used super glue to hold the plastic onto the lights.
Step 5: Making the Shirt
I selected a shirt with a pocket to hide the cut I made for the wiring of the light. I cut a small hole behind the fabric of the pocket where the light would fit through. Then I cut a square of fabric that would act as a pocket inside the shirt for the Linkit One. I folded the edges of the fabric over and used a simple stitch to attach it to the bottom of the shirt on the same side as the light.
Step 6: Putting It All Together
I put the light in the pocket and then connected it to Linkit One. I made sure the battery and wifi antenna were connected. I switched the Linkit One to battery.
Epilog Contest VII
Wearable Tech Contest
Make It Glow! Contest
