Introduction: How to Build a Faux Fireplace That Looks Real
I love fireplaces, but unfortunately my current rental apartment doesn't have one. So I wanted to figure out a way of making one that looked real and could be removable so I can take with me when I move out. I wanted it to be very modern and simple to build without a workshop. I built my design around this electrical log insert. It's important to note that even though it has a heater feature, I am not going to use it as a heater
*** this is a decorative faux fireplace only, not to be used as a heater ***
To build this structure. I use 2"x3", but you could also use 2"x4".
For the firebox, top and bottom, I used 1"x12" boards
For the skin of the fireplace, I used 1/4" plywood
For the mantle, I used 3/4" plywood, 1"x4", 1"x2"'s
For the finish, I used peel and stick tiles and paint
Step 1: Decide on the Scale of the Fireplace
I don't have any pictures of this but I used cardboard pieces tapes to the wall to see how different shapes worked best for my living room, considering the size of the faux fireplace insert .
Step 2: Assemble the Frames
These are simple rectangular frames - there's 4 of them.
Step 3: Attach the Side Pieces of the Firebox
Here the key is to line the pieces so that they are at the same height
Step 4: Attach the Top and Bottom Pieces of the Firebox
Simply prop up 2 of the frames and screw in place the top and bottom pieces, using a speed square to make sure they are at 90 degrees.
Step 5: Attach the Bottom and Top Piece
Attach the bottom piece, centered in the middle of the firebox, and then attach the remaining 2 frames on each side. Add the top piece to complete the frame. I've included pics showing the dimensions of my fireplace, but as I mentioned earlier, the nice thing about building your own fireplace is that you get the decide on the dimensions that work for your room.
Step 6: Attach the Plywood to the Front, Sides and Back
I used 1/4" plywood to enclose the structure. For the back of the firebox, I drilled a hole, using a hole saw, to be able to pass the electrical cord of my faux fireplace insert.
Step 7: Finish the Outside With Peel and Stick Tiles
The peel and stick tiles I used require a painted surface, so I painted the plywood, and then stuck on the tiles. Very easy and fast, and I liked how they had the look of stone.
Step 8: Build the Mantle
I built the mantle with dimensional lumber I had on hand, basically building a frame with 1" x 4" attached to 3/4" plywood and then I added 1"x2" to the bottom to close the gap (the mantle sticks out by 1 1/2" all around. I painted it since it wasn't very pretty wood, but it would be easy to add a nice slab of wood instead.
Since the fireplace is narrow and tall, I recommend attaching it to the wall so it doesn't fall over.
Step 9: Add the Faux Fire Place Insert
I was very impressed with how real this faux fireplace looks. Even though I'm not using it as a heater (*** this is a decorative faux fireplace, not to be used in heat mode in this project ***) it still sets the mood and looks great. I love it.
Step 10: Decorate for the Holidays
I hope you enjoyed this project - there's also a video of the project, it that's your thing.
Plywood Contest
