Introduction: How to Make DIY Wireless RC Car Without Arduino Code
Hi guys, we will be showing you how to make DIY Wireless RC Car without Arduino Code, Easy Made, 100% Work and Low Cost.
This MB-46-T RF Wireless Transmitter kit is designed to send signal wireless and turn on or off the relay at MB-46-R Receiver Kit. The MB-46-T kit is using the RF Transmitter 315MHz module to send the frequency/signal.The basic concept of this kit was using the HT12E IC which can simply converts 12 bit parallel data in to serial output and it can be transmitted through a RF transmitter. These 12 bit parallel data is divided in to 8 address bits and 4 data bits. By using these address pins we can provide 8 bit security code for data transmission and multiple receivers may be addressed using the same transmitter.
This MB-46-R RF Wireless Receiver kit is designed to receive signal from the MB-46-T RF Transmitter Kit by using the RF Receiver 315MHz module. There have 4 on board relays which will be on once detect the signal from MB-46-T RF Transmitter Kit. The relay can be used to connect to the external load.The basic concept of this kit was using the HT12D IC converts the serial input into parallel outputs. It decodes the serial addresses and data received by, an RF receiver, into parallel data and sends them to output data pins. The serial input data is compared with the local addresses three times continuously. HT12D is capable of decoding 12 bits, of which 8 are address bits and 4 are data bits.
Let's get started!
Step 1: Gather Your Things Up!
Basically, all you need for this project is:
- MB-46-R RF WIRELESS RECEIVER KIT
- MB-46-T RF WIRELESS TRANSMITTER KIT
- 2WD SMART CAR CHASIS 2 WHEELS
- 9v Battery
- LI-ION RECHARGABLE BATTERY 7.4V 1200MAH
- 4x Push Button Momentary NO (Normally Open)
- DC Jack (Female)
- Multicore wires
All of list above available at Mybotic. So, you can get it at our store.
