Introduction: How to Make a Custom Doormat
Customized doormats are ALL the rage today. And now that we’ve made one, we can see why! While they may seem daunting, we found a super easy way to make your own custom welcome mat using just a few materials. Best of all, this project only takes a couple of hours from start to finish, so all you need is a free evening and a well-ventilated area. :)
Get those creative juices flowing, bust out your cutting machine, and let’s do this!
(Amazon Links = Affiliate Links)
Outdoor mat - https://amzn.to/2HYaXlc
Flex Seal Spray (Black) - https://amzn.to/383uaNu
Flex Seal Spray (Clear Coat) - https://amzn.to/3mDnJ7Y
Stencil Blanks (We used Showcase from Hobby Lobby, but these could work too) - https://amzn.to/3oRGoyE
Cutting Machine (I have the Cricut Maker) - https://amzn.to/2I0OHHZ
Deep Cut Blade for Cricut - https://amzn.to/322f0Eo
Straight Pins - https://amzn.to/3oRyw0g
Frog Tape (strong green painter’s tape) - https://amzn.to/2HXdQDn
Drop Cloth - https://amzn.to/3oSPdrU
Respirator Face Mask - https://amzn.to/2TOy7NS
Affiliate Notification
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites. You don't pay anything extra for the items you buy - we just get credit for referring you!
Step 1: Design and Cut Stencil
Let the fun begin! Just pick a design or saying that you want to have on your outdoor mat, and then get to cutting it! We used the Cricut Maker to do this part.
Gather the following materials: computer, Cricut machine (or other cutting machine), related cutting machine accessories (mat and blade), stencil blanks
Follow these steps:
1. Create preferred graphic or saying in Cricut Design Space.
2. Adjust dimensions until graphic is the desired size.
3. Click “Make It” to send the project to the cutting steps.
4. Adjust graphic on your digital mats so you have enough of a border on each side to tape down the stencil, once made.
5. Adhere stencil blank to a Standard Grip Mat.
6. Insert the Deep Point Blade to the B slot in your Cricut machine.
7. Load mat in machine and press the go button.
8. Remove letters from sheet, but be sure to keep the insides of the letters (A, E, O, etc.) .
9. Repeat for second mat, if your design calls for it. (we used two stencil sheets in total).
Step 2: Secure Stencil to Outdoor Mat.
Woo hoo! Now that you have your stencil, all you have to do is get it secured to your outdoor mat.
Gather the following materials: cut out stencil, Frog tape, outdoor mat, straight pins
Follow these steps:
1. Trim stencil as needed for your preferred alignment.
2. Place stencil pieces on outdoor mat, ensuring that they are centered.
3. Tape stencil down using the green Frog Tape.
4. Place the insides of any letters (like O, D, E, etc.) in place.
5. Use straight pins to secure stencil to mat, being sure to pin down all insides of letters.
Tip: You can’t use too many pins here. The more secure the stencil is, the less bleed you will have.
6. Cover any additional areas of the mat where you do not want color (this has a lot of overspray).
Step 3: Paint Mat With Flex Seal
This is where your mat really comes to life! Just be sure that you’re working in a well ventilated area, as the Flex Seal has a STRONG vapor. We highly recommend using a face mask and goggles as well.
Gather the following materials: drop cloth, face mask/respirator, flex seal (black), flex seal (clear)
Follow these steps:
1. Place a drop cloth under your project to protect surface from overspray.
2. Shake can to ensure it is properly mixed.
3. Hold the can of Flex Seal about 12 inches from your project.
4. Spray straight down, not at an angle, moving quickly across the stencil.
5. Let dry for approximately 15 minutes.
6. Spray a second coat using the method described above.
7. Let dry for approximately 15 minutes.
8. Seal with the clear Flex Seal spray, if desired.
9. Immediately after sealing, remove stencil by lifting it straight up and away.
10. Don’t forget to remove the insides of the letters as well.
11. Let project cure overnight.
Step 4: Enjoy!
Now just place your new welcome mat outside and enjoy! You can dress this up in many ways, including using another larger mat underneath to help it pop.
We hope you enjoyed this project. Let us know if you make it.
In the meantime, if you liked this project, please head over to JustMightDIY.com for more tips, tutorials, back stories and more. And if you’re interested in checking out more of our tutorials, check out our Instructables profile or head over to our YouTube channel.
1000th Contest
