Introduction: Simple Farmhouse Crochet Table Runner
I love making home made decor items. Handmade Crochet Projects definitely adds a personality to your home ambiance. A crocheted table runner is the perfect project to add elegance and jazz up your home decor.
Crocheted Table Runners are the best for your dining tables since they are typically worked lengthwise for the center of the table. They can also be worked in a variety of shapes and sizes right from the traditional rectangular runners to sophisticated circular oval patterns.
Today am sharing the pattern for Simple Farmhouse Crochet Table Runner Pattern. This is a part of the 2024 International Crochet Month Blog Hop being hosted by Marie from Underground Crafter.
The pattern is quite simple made with the basic stitches. You can alter the table runner accordingly to lengthen or shorten the size. This is an easy home decor crochet pattern that you’ll enjoy making. They would also make awesome gifts for your loved ones.
Visit https://rajiscrafthobby.blogspot.com/2024/03/simple-farmhouse-crochet-table-runner.html
4 Ply Cotton Knitting Yarn
4 mm Crochet Hook
Step 1:
Here is the Video Tutorial:-
You can follow along with this tutorial video. Please be sure to subscribe too!
Step 2:
Round 1:-
Start with a Slip Knot.
Chain 35 +2 Chains extra for the turning chain.
This measures around 8 inches.
You can adjust the size by altering these stitches according to your requirement.
Start with any Multiple of 7 + 2 Chains Extra for the turning chain.
Step 3:
Round 2:-
1 Double Crochet in the 5th Chain from the hook.
1 Double Crochet each in the remaining stitches.
Once you reach end, Chain 2 and use the Straight Edge Turning Chain to make the turning chain.
Straight Edge Turning Chain:-
Usually you would Chain 2, turn and start working the next round. Here is a quick tip to have a nice straight edge .
- Insert the hook into the 1st chain from the bottom.
- Yarn over and pull up a loop. You should have 2 loops on the hook.
- Turn your project and insert the hook into the first stitch.
- Yarn over and pull up a loop. You will have 3 loops on the hook.
- Again, yarn over and pull through 2 loops. You will have 2 loops on the hook.
- Lastly, yarn over and pull through 2 loops.
- This will make one Double Crochet.
Step 4:
Round 3:-
(1 Double Crochet is already made while making the turning chain)
1 Double Crochet in the same stitch(that's total 2 Double Crochets)
Chain 2.
Skip 5 stitches.
1 Double Crochet V - Stitch(i.e. 2 Double Crochets, Chain 1,2 Double Crochets-all in the same stitch)
Chain 2.
Skip 6 stitches.
Repeat1DC V-Sti, Ch 2, Sk 6).
At the end you will have 6 stitches left Skip 5 Stitches.
2 Double Crochets in the last stitch.
Once you reach the end ,Chain 1 and turn your work.
Step 5:
Round 4:-
1 Single Crochet in the 1st stitch.
Chain 1.
**Next 2 stitches , we will be making it into the stitches from 1 Round below(i.e. the previous round.)
Skip 1 stitch(of the previous round)
1 Double Crochet each in the next 2 stitches from 1 Round below (i.e. the previous round)
Chain 2.
1 Single Crochet into the Chain 1 space of the V-Stitch.
Chain 2.
Skip 2 stitches(of the previous round)
Repeat(1DC each in 2 Sts from 1 Round below,Ch2,1SC into the Ch1 Sp of the V-St,Ch2).
Chain 1.
1 Single Crochet in the last stitch.
Once you reach the end ,Chain 2 and use the Straight Edge Turning chain to make the turning chain.
Step 6:
Round 5:-
1 Double Crochet in each of the stitches.
(i.e :- **1 Double Crochet in the Chain 1 Space,
1 Double Crochet each on the next 2 stitches.
2 Double Crochets into the Chain 2 space.
1 Double Crochet on the Single Crochet.
2 Double Crochets into the Chain2 space.**
Repeat from ** to **.
1 Double Crochet into the last Chain 1 space.
1 Double Crochet into the last stitch.
Step 7:
Round 6 Onwards:-
Keep Repeating Round 3 , Round 4 and Round 5 untill the size needed and weave off.
