Introduction: Simple Carabiner Altoids Tin Hack.
In this tutorial I will be showing you how to attach an Altoids tin to a carabiner so you can clip your survival kits where ever you want for easier transportation.
I hope you like this instructable if you do please vote, subscribe and like.
thanx #P1XEL00
Step 1: What You Will Need.
you will need
- Paracord
- mallet
- flat head screwdriver
- knife
- Altoids tin
- carabiner
- Lighter
- vice
Step 2: Mark Your Holes.
Mark where you will be putting your holes to put the Paracord through and make sure they are evenly spaced and don't go too far up or down and put it on a corner where it won't prevent the box from opening.
Step 3: Poke the Holes.
Put the Altoids tin with the marked corner facing up and gently tap the knife with the mallet to poke the holes.
Step 4: Create an Indent.
create an indent by putting the Altoids tin in the vice sideways and tap the portion between the metal gently tapping and pushing the piece out.
Step 5: File It Down.
File the edges making sure nothing is sharp and the bumps that might have formed along the indent.
Step 6: Put the Paracord Through the Hole and Tie the Knot.
You will need to insert the Paracord into the hole of the indent you made and make it even on both sides.
Tie a knot with both ends of the strings cut off the excess and use the lighter to melt it together.
Step 7: Put on the Carabiner and Finish.
now put on the carabiner and you are done.
show it off wear it on your belt loop or on your backpack or put it on your water bottle the possibilities are endless.
I hope you enjoyed share it, subscribe, like and stay awesome.
Small Spaces Contest
On a Budget Contest
MAKE ENERGY: A US-Mexico Innovation Challenge
Burn It! Contest
