Introduction: Tutorial to Interface OLED 0.91inch 128x32 With Arduino UNO
This tutorial is going to teach you some basics on using OLED 0.91inch LCD128x32 with Arduino UNO
Step 1: Introduction
Description:
OLED 0.91 inch is a monochrome graphic display module with a built-in 0.91 inch, 128X32 high-resolution display. OLED 0.91inch is able to work despite the absence of backlight. In a dark environment, contrast of OLED display is higher than LCD display. This device is I^2C or SPI compatible. Due to its capability in displaying, it is often used in various application for instances, smart watch, MP3, function cellphone, portable health device and many others.
Specifications:
1. OLED display, no need backlight, self-illumination,
2. The display performance is better than the traditional LCD display, also lower consumption.
3. Driver IC: SSD1306
4. Size: 0.91 inch OLED
5. Resolution: 128 x 32
6. IIC interface
7. Display Color: white
8. Description:
GND: Power Ground
VCC: Power + (DC 3.3 ~5v)
SCL: Clock Line
SDA: Data Line
Step 2: Pin Definition
Step 3: Hardware Installation
Step 4: Sample Source Code
To get the result, please download the sample source code attached below.
*Kindly download the U8g2 library which is written for many types of LCD display.
Step 5: Include U8g2 Library
Click skecth and then click include library. Next, click add .Zip library and select the U8g2.zip file.
Step 6: Upload Source Code
Open the source code. Make sure com of arduino UNO and com port is same and please select the board is Arduino UNO.
Click upload.
Step 7: Result
