Introduction: Warm Daytime Eye Makeup Look!
This instructable guides you through the steps to achieve this simple day time eye makeup look.
you will need an eyeshadow palette with warm toned nude colors.
A primer for the eye lids(I'm using the primer by younique) primer helps make the eyeshadow more intense, and prevents creasing.
eyeshadow brushes: crease brush by sephora, shadow brush by sephora and a angled liner brush
A mascara of your choice, I'm using the fiber lash mascara by younique.
Step 1: Prime and Define Brows..
Prime your eye lids and around your eyes. And then define and shape your brows using a brow product of your choice.
Step 2: Base Color..
Using a flat shadow brush apply this champagne pink color all over the lids as a base color. And apply some on your brow bone to highlight the arch of your brows.
Step 3: Crease Color..
I'm going to be using the matte brown shade and the shimmery grey color for my crease and the outer corner of my eyes. Take both the colors using a crease or blending brush, tap away excess and apply it to the outer corner of your eyes and bring it halfway into your crease to define the crease. Blend out the harsh lines. using an angled liner brush apply the same two colors right below the lower lash line.
Step 4: Brighten Inner Corners..
Apply a similar gold color on the inner corner of your eye and on the tear duct area to brighten up your eyes.
Step 5: Finishing Touches..
Apply liquid liner in an appropriate way according to your eye shape. i did a winged eye liner look. please take a look at my eye liner tutorial for eyeliner application guide for different eye shapes. click here
line your water line using a black smudge proof kajal, I'm using the black shadow pencil by maybelling new york.
Step 6: Mascara
Finish your look using a mascara of your choice and false eye lashes if you like. Clean up any fall out on your cheeks using a wet wipe and finish up the rest of your makeup. I hope this instructable is beneficial for you. Thank you xx
Hair and Makeup Contest
Before and After Contest
