Introduction: $12 Bluetooth Upgrade
I've been using a wired aux in connection in my car or a while. I'm just too cheap to upgrade my radio.
I decided to cut that cord and still not spend too much. I was going to use a little bluetooth module in a cigarette lighter to usb adapter but then I'd have to deal with people asking "whats that?". I decided to hide it under the dash instead.
I bought a lot of the parts at the local Radio Shack Super Sale. The Bluetooth module was $3.68 on ebay...
Step 1: The Bluetooth Module
First thing is to carefully pry it open and remove the board. I used a small RS project box. It easily fits all the components I'll need.
Those are:
LM7805CV 5V linear regulator
.01uF caps(2 pcs)
47uF Electrolytic Cap
1A 5x20 fuse and holder
RS project case
RS protoboard
Step 2: Fitting the Module to the Box
I drilled a hole for the audio in as close to the bottom as possible. Then I removed the ribs so the jack would fit as close as possible to the wall.
This made the outside perfectly flush...
Step 3: Freebie Heatsink
RS gives you two covers. One plastic and one aluminum. I drilled out the holes in the aluminum cover to fit around the posts of the plastic cover.
This way I could sandwich the two together. I mounted the regulator to the plate with a generous blob of heatsink compound and a small 4-40 screw/nut. Once cleaned up and trimmed down it fits nicely between the two covers.
I folded a small section of the bottom edge over to route the wires from the regulator.
Step 4: Final Assembly
I mounted all the parts on a small protoboard. See Fritzing schematic....
I used a USB socket I had salvaged from a hub to connect to the audio module.
I mounted the USB socket with a BIG blob of hot glue where is would apply enough pressure against the audio jack to keep the module in place without any other mounting. Just in case I ever want to reuse that module....
Step 5: Testing and Use
I hid everything behind the glove box and used the blue power antenna wire from the radio for power. This way it only powers on with the radio.
The module I got plays and audio clip that says "bluetooth ready" on power up. It lets everyone know I upgraded.
Now I can leave my phone in my pocket rather than have it floating around the dash while I'm driving........
