Introduction: 120 PSI - Air Gun
This project was inspired by Luke S. Video on YouTube about how to make an air gun. This project will cost $20 or less and take very little time to construct. You will need:
1 Foot 1.5" PVC pipe
1.5" Cap
1.5" Coupling
1.5"x1/2" bushing
1/2" Tee
1/2" female adapter
1/2" elbow
1/2"x1/4" brass bushing
1/4" threaded tire valve
1/2" ball valve
2 Foot 1/2" PVC pipe
1.5" Cap
1.5" Coupling
1.5"x1/2" bushing
1/2" Tee
1/2" female adapter
1/2" elbow
1/2" ball valve
Step 1: Line Up!
Just simply lime up your pieces like the picture
Step 2: Lineup 2
Where you see the red circles, is where you should insert pieces of you 1/2" PVC tube- (to connect the pieces) The 1/2" PVC tube you bought needs to be cut so you can put various lengths in between the pieces
Step 3: Connect Pieces
Apply primer and PVC cement to the ends of each piece and simply connect
Step 4: Barrel
you can add a barrel to the valve (shown in picture) although it is not necessary
Step 5: Pump It Up!
Connect a bike pun to your tire valve and pump air into it READ IMPORTANT BELOW
NO MORE THAN 120 PSI OR IT COULD EXPLODE
Step 6: EXTRA INFO
DONT FORGET TO PUMP NO MORE THAN 120 PSI
Use paintballs or small objects - BE SAFE AND SMART - Please don't be a derp while shooting this - I don't want ANY Injuries
