Introduction: 3 Dimensional Tire Ball
Just thinking of writing repetitive code may seem really boring and painful to endure, but with the use of variables and loops through the interface of Tinkercad Codeblocks you can create a 150 Primitive project that turns into a really cool 3D Tire Ball.
Follow These Easy Instructions to create a 3 Dimensional Tire Ball of your own with Tinkercad.
Hope You Enjoy!
Step 1: Creating the Variables
These may seem to be some very wacky numbers right?
They become the base layer for the actual design, but can be formatted if you would like
- Start with creating a variable named length, and set that as the Square Root of 3 plus 4 times 5
- Add a second Variable named Width, and set that as length divided by the square root of 2 minus length
- Add a third Variable named Depth, and set as length times Width plus Length minus Width
- Add a Fourth Variable named Spacing and set that as Length times Width times Depth plus the Square Root of length minus Width + 3.14
- Add a Fifth Variable named Area Form, and set that as length divided by width times Depth minus Spacing plus (Sin) 12.345
- Finally Add a Sixth Variable named #oftimescreated and set this to be one
Note: At this point in time this Variable can only be set to one currently because Tinkercad limits the amount of Primitives to be 200
Step 2: Creating the Three Dimensional Layers
The Three dimensional layers consist completely of Tubes and grouping
- Start by creating a New Object
- Add a count with loop set as, count with (any) from 1 to #oftimescreated by 1
Inside:
- Add a rotate around Axis x by Area Form Degrees from pivot (x:0 y:0 z:0)
- Add a count with loop set as count with Area Form from 1 to 100 by 2
Dimension #1
Inside:
- Add a Solid Tube With a Radius of length times width times 1 divided by Depth
- Add a Scale of (x:5 y:5 z:5)
- Add a Rotate set as, Rotate around Axis X by Area Form times Spacing Degrees from pivot (x:0 y:0 z:0)
End The Loop:
- Add a Create Group (multicolored)
- Add a Rotate set as, Rotate around Axis x by 90 degrees from Pivot (x:0 y:0 z:0)
- Add a count with loop set as, count with Area Form from 1 to 100 by 2
Dimension #2
Inside:
End The Loop:
- Add a Create Group (black)
- Add a Rotate set as, Rotate around Axis y by 90 degrees from Pivot (x:0 y:0 z:0)
Dimension #3
Inside:
End The Loop:
End All Loops
Note: If you would like to increase the #oftimescreated turn up the number of the variable and turn up the number of steps taken in the three innermost loops Ex: count with Area Form from 1 to 100 by 2 —> 3-5
Step 3: Some Finishing Touches
All that is left to do is to add in that sphere hole in the middle of the ball and to Create it as a Group
- Add a Sphere with a radius of 20
- Create Group
And There You go, your own 3 Dimensional Tire Ball with 151 primitives
Note: This is best run on full speed while creating the ball so it doesn’t take as long depending on your device and Connection it may take different amounts of time but normally runs much faster after loading a couple of times through
