Introduction: 3-Ingredient Butterscotch Fudge
About: Hello and Welcome to In the Kitchen With Matt. I am your host Matt Taylor. My goal for the show is to teach you how to cook really good food at home for cheap. Eating out everyday can get expensive, but it doe…
In this Instructable, it's time to dive into the world of fudge and learn how to make a super easy butterscotch fudge with just 3 ingredients. Fudge making is fun and doesn't have to be complicated. If you are a butterscotch lover and fudge lover this homemade butterscotch fudge recipe is for you. It is creamy, soft, and so delicious.
Don't forget to follow me and check out my other Instructables :)
Follow the simple steps below or watch the short video tutorial or do both!
Ingredients:
  1. 1 14oz can of sweetened condensed milk (396g)
  2. 1/4 cup of unsalted butter (55g)
  3. 2 1/2 cups of butterscotch chips (450g)
Tools/Equipment:
  1. Microwave safe bowl
  2. 7x11-inch pan or 8x8 inch pan
  3. Parchment paper or wax paper
  4. Spatula
Step 1: Heat Condensed Milk and Butter
Add the sweetened condensed milk and the butter to a microwave-safe bowl. Then heat on high in the microwave for 2 1/2 to 3 1/2 minutes until the butter completely melts. It will get airy and bubbly while it heats up, that is normal. Stir it at the 1-minute mark.
OR
You can pour both ingredients into a medium pot, use medium heat, and heat it up on a burner if you do not want to use a microwave. Make sure to stir regularly until the butter melts and it gets a roiling bubble.
Step 2: Add Those Chips
Now remove the very hot milk from the microwave or the burner if using a pot on the stovetop and pour all butterscotch chips in it. Push them down with a spatula. Then wait for about 5 minutes.
Stir well until you have a nice thick butterscotch fudge.
Step 3: Chill That Fudge
Pour the fudge into a 7x11 or 8x8 inch pan lined with parchment paper or wax paper. Use a spatula to spread it out evenly if needed.
Place the fudge in the fridge and let it cool/set for 30 to 60 minutes or longer, sometimes it takes a few hours to set properly.
Step 4: Cut and Serve
Remove the cold fudge from the fridge and slice it into squares.
TIP: If your knife is sticky you can try spraying it or rubbing it with a little cooking oil or run it under hot water to heat the knife then wipe it off. The hot knife will cut through the fudge more easily. If the fudge is still fairly soft you can put it in the freezer for 15 to 30 minutes then try cutting it.
Enjoy!
*Print the written homemade butterscotch fudge recipe here.
Step 5: Video Tutorial
Now watch those steps in action with this short video tutorial.
