Introduction: 3 Smartphone Solar Charger
Hello Friends toad I made a some spacial for free energy lover. All you-tubers make free energy smartphone charger with DC Motor but this project not work well.
Solar is a very highest part of renewable energy. My Solar Charger Work with 3 voltage regulator LM7805 and I use 10.72 volts solar panel.
My Solar charger can charge up-to 3 smartphone in happy sunny weather. This is simple way to save electricity. I am fixed my solar panel in my roof and at morning 8'O clock start my solar panel automatically and evening 4'O clock solar automatically switched off.
You can also use 12 volts and 15 volts solar panel for more speed.
Step 1: Parts Needed
Step 2: Circuit Diagram
The circuit is very simple to make you can use PCB for this project.
Follow the circuit diagram step and build the circuit. This is very simple voltage regulator LM7805 .
First make circuit than fix the heatshink. If your Solar Panel makes Ac voltage so connect 1N4007 Diode in starting of connection.
Step 3: Know More Voltage Regulator
Linear Regulators. One of the most basic ways to regulate voltage and provide a stable voltage for electronics is to use a standard 3-pin linear voltage regulator such as the LM7805, which provides a 5 volt 1 amp output with an input voltage at up to 36 volts (depending on the model).
Step 4: Join Us.
So Friends if yore solar smartphone charger work well, than comment and any problem also comment me.
Go to my new website for more best projects Truescience22 and know more about interesting technology to go my new facebook page Facebook .
