Introduction: 3-ingredient Makeup Remover
Okay, so a few tips first.
1.) Don't you dare use this around your eyes because if you do and it gets in them they will burn like the fires of hell so please don't.
2.) Depending on what makeup you use it on, you may have to scrub more to get it all off. Lipstick and stick eyeliner are the worst, while eyeshadow and liquid liner are the easiest.
3.) When I used this I used a little bit of water at the very end to get off any soap residue, but since there's lotion involved I didn't use water every time.
Alright, let's do this!
Step 1: Assembling Your Lovely Ingredients
They are as follows,
-Softsoap Moisturizing Body Wash (any scent, I just used 'Juicy Pomegranate & Mango Infusions'.)
-Neutrogena Body Lotion (yes, that does say 'light sesame formula' if you really want to know.)
-Aussie Conditioner in 'Aussome Volume' because it's what I have right now.
-A little cup for mixing in.
-A brush or stick for mixing.
-A cottonball or tissue for wiping it off in the end.
Step 2: Squeezy Time!
1.) First, start with the Conditioner.
Put in a good little dollop of it, this will be your base and biggest amount you add.
2.) Second, go with the Body Wash.
Add an amount of Body Wash that's about a third of the amount of the Conditioner.
3.) Lastly, add some Body Lotion!
Give the mix two little blobs of the stuff.
Step 3: Mixy Mixy!
Now, just pick up that brush/stick of your and mix the three together!
Yay! Fun!
Step 4: Use Your Masterpiece!
I used my mixture on stick eyeliner which took a bit of scrubbing, but when I used it on my eyeshadow from a cosplay, the eyshadow came off in seconds. But use it on what you want, the possibilities are currently endless.
So, best of luck to you, and I hope you enjoyed this!
Bye for now!
