Introduction: 3D Buildings on Grid Paper!
Hey guys! I'm back, doing my first post in a while: a tutorial on something cool to do on graph paper. You draw 3D models of buildings and stuff, and I think it's sorta a fun thing to do when bored. This instuctable might be more of a concept than a step by step, but it's still basic. Enjoy!
I just made a Papercraft version of this. Head on over with this link and make sure to check it out!
Step 1: Stuff You Need
You will need:
- Pencil (a regular mechanical pencil or #2 would do well)
- Some kind of thin marker like a Sharpie Pen (if you want to outline it in black ink)
- Graph paper (or printer paper if you don't want the grid guidelines)
- One of those shader things or finger (for shadows if you want them)
Step 2: Drawing
Rotate the paper a bit so the squares are at a 45 degree angle. Start doing a basic outline of the building in pencil.
Step 3: Outlining
Once you're sure of the final design, you can outline it with a thin pen/marker.
Step 4: Shading
TWO METHODS:
1: Finger
Shade the areas that would have shade lightly, then rub it with your finger to spread it around.
2. Shader thing
Sorta scribble around that area that would have shade and use it like a pencil to make shade.
Step 5: Optional: Cutting
This is an optional step that is for people that want to make their drawing into an anamorphic illusion. To do that, use a pencil and lightly sketch the base. Make a dot on the farthest corner from you (shown in the picture). Trace along the line that aligns with the dot where the line come out of the drawing is where you will cut. If this is confusing, the picture captions will probably help. Trace an outline for the paper that the building will be on (make room for the shadow) and cut it out. When you get to the lines that you sketched, just cut the building outline.
Step 6: Done!
You now have a cool cube-like 3D building. Thanks for reading this 'ible!
