Introduction: 3D Modeling House on 3Ds Max Project
The program that is being used is 3Ds Max
Step 1: Layout the Floor and Make the Walls
Start by making the layout of what you want your house to look like and where you want certain rooms to be. Change things around as needed.
Step 2: Modeling Furniture and Objects
Now that the ground work has been laid down, it is time to start modeling what is going to be going into your rooms by using the basic shapes provided. Once the objects are done, then you can place them in the house however you want.
Step 3: Texturing and Colors
Once everything is in the house, then you can start to apply the colors and the textures that you want.
Step 4: Camera and Lighting
Now to get ready for the rendered animation, lighting is very important so you can see what's happening, but at the same time not be blinded. After lights are placed and adjusted, you can then add the camera where you want to get ready for the animation.
Step 5: Render Animation
The last step is to now render the animation. First go to the view of the camera then press the teacup with the cog at the top of the screen then save the file as .avi to wherever you want. Then press render at the top once the file was saved. The video will now render out, and once it's done it will automatically save.
