Introduction: 3D Printed Fishing Lures
Fishing lures can get expensive at $5 or more a piece, and much of the time they can get lost and destroyed- So why not print your own for pennies!
You can also 100% customize colors, sizes, patterns and bouyancy
Step 1: What You'll Need
Here's what you'll need
-About 20 inches of Fishing line (I recommend using heavy braided line)
-a Swivel connector
-2 treble hooks
- A 3D printer and the .STL files which you can get here - EB Tool Co - 3D printables - There's two different types and a spinner you can print to add more attention or build a spinning lure.
* I used orange filament, there are probably many colors that would work well - I just got in some glow in the dark filament that I can't wait to try
Step 2: Printing and Adding the Line
Just download and print the file. If you don't want the lure to float you can either print it solid (no hex or triangle fill) or you can do what I did and use a hex fill pattern and pause the print to add split-shot sinkers in the middle of the hexes. - If you can't do either of those you should also be able to add split shot sinkers to the hook lines (though that's not ideal)
You'll notice after you print the body that there are two sets of holes running through - you'll want to string your line through like this
Step 3: Swivel
Now it's time to string the swivel and tie it on the front
Step 4: Hooks
Next just tie on the Hooks
Step 5: Triming / Finishing
Then just trim the lines, paint it up however you like - and get to fishing!
