Introduction: 3D Printed Music Stand
3D printed music stand with adjustable height and angle.
Step 1: Components Required
  • PLA Filament
  • PVC - 1(Outer diameter: 20mm, Inner diameter: 18mm)
  • PVC - 2(Outer diameter: 25mm, Inner diameter: 21mm)
  • M6 Nut and Bolt with Washer * 1
  • M5 Nut and Bolt * 1
  • M3 Nut and bolt * 4
  • Exam pad or 5mm MDF
  • 2 Compound adhesive
Step 2: Stl Files
Download stl files from the below provided link. Print all the files.
https://www.thingiverse.com/thing:4633755
Step 3: Preparing 3D Printed Files
    Insert Nut and Bolt according to the images and apply 2 compound epoxy adhesive.
    Step 4: PVC - 1 (Inner)
      Drill holes according to the images.
      Step 5: PVC-2 (Outer)
      • Cut 5.5mm width slot of length of 150mm .
      • Insert inner pvc into outer pvc.
      • Insert PVC-2 to the 3d printed base and apply 2 Compound adhesive.
      Step 6: Preparing Exam Pad
        Drill holes and screw 3d printed files accordingly. Apply 2 Compound adhesive.
        Step 7: Final
        Done.
