Introduction: 3D Printed Street Fighter Headlamp With Demon Eye
Full 3D printed Street Fighter-style motorcycle headlamp, Inspired by Ducati Headlamp. Using Devil Eye Animated LED and Mini projector lamp.
https://www.thingiverse.com/thing:6849199 or https://grabcad.com/library/3d-printed-street-fighter-headlamp-1 or https://www.printables.com/model/1124956-3d-printed-street-fighter-headlamp
Download all the 3D parts from the link above
I print it using ABS filament but u can use other material that can survive in the hot temperature course by weather or by the lamp...
Step 1: Choose the Suitable Projector Lamp
Find the suitable lamp for your headlamp, I use two duromoto GP1 and stack them to become one lamp.
u can measure using 3d obj I have listed or u can modify the enclosure.
Step 2: Demon Eye
there are a lot of demon eye LEDs u can choose from, just pick one that is suitable for u combine it with a 59 mm lens, and stack it together
Step 3: Threaded Knurled Brass Insert Nut Round and Bolt
i'm using
M3 4mm Threaded Knurled Brass Insert = 8
M6 8mm Threaded Knurled Brass Insert = 4
M3 10 mm Bolt = 8
M6 10 mm Bolt = 4
Step 4: Assemble It Into One
using hot iron solder, place the Threaded Knurled Brass Insert and assemble it together
Step 5: Finishing
for good results, I use putty and burn it several times starting from sandpaper grid 180, 350, and 600 then after that, I paint it with surfacer paint and paint it with paint that matches your vehicle. but if you want it stronger, I suggest adding fiberglass and resin on the inside to make it stronger and painting it with epoxy surfacer paint on the outside
and the result u can check this video
