Introduction: 3d Print Custom Covers for Pendrive
Hi All,
Today I will share, how to customize your USB flash drive or Pendrive with super cool cases
Step 1: What Do We Need?
- Chip version - Pen drive
- Tinkercad
- 3D printer
- Imagination
Step 2: Base Shape
- To make a custom case,
- we need a simple image like batman logo or ghost etc
- or a STL file like among us or lego
- If you have decided to use simple Image
- Download a black and white image from google (best results with black and white)
- Using any jpg to SVG convertor, convert into svg (eg: https://www.pngtosvg.com/)
- Alternatively, you can download STL model from Thingiverse or cult3d or many other sites
Step 3: Tinkercad
- Tinkercad is a simple online 3D modelling tool
- Import your model or Image in it. I will use an image
- Import the attached SVG into Tinkercad
- Adjust the dimensions to 25x 40 x 5 mm
- Add two holes for eyes
- Based on the USB drive dimensions make another hole
- I am showing the placement of this hole by making the ghost also a hole (works like x-ray)
- Now create a duplicate and invert by 180 degrees
- Using holes cut the two models into upper body and lower body
- We have our 3d model ready to print
Step 4: Ghost
- Download the STL file from here
- Resolution : 0.2mm
- Support: Tree (Cura)
- Raft: No
- Print time: less than 1 hr
- Once printed, superglue the USB drive an we are done
Step 5: Batman Logo Pendrive
- Follow the same steps as the Ghost image to make the batman logo Pendrive case
- Raft: No
- Once printed, superglue the USB drive and we are done
Step 6: AmongUs Pendrive Case
- An existing 3d model was imported in tinkercad
- Shrink it to the dimensions and then create a hole based on the USB dimension
- Duplicate and cut into half
- Raft: NoPrint time: less than 1 hr
I hope you enjoyed reading, Do share if you print these or create your own design
