Introduction: 3d Printed WALLET
IF YOU ARE FED UP WITH YOUR OLD WALLET TRY ME!
HANDY AND STYLISH WALLET FOR CASH, COINS, DOCUMENTS AND CARDS!
JUST PRINT IT!
3d files awailable here:
http://www.thingiverse.com/thing:1749733
Step 1: What Is It About?
The idea is simple. Came to me when I started to be fed up with my older big wallet. It was to big to wear it in the pocket.
I decided to create something handy, but big enough to carry all my valuable things like cash, documents, credit cards and few coins.
Designed wallet is really funcional. Most precious things are inside, but if you want to take few coins quickly you just turn the switch and you can easily pour the money.
Step 2: 3D PRINTING
Ok so lets start printing on Your or someone's else 3d printer.
The object is really easy to print, You just have to put all the parts on their base (see the photo), and print it! :)
In my case, printing on Plug N Play 3d Printer , I just choose layer height Z=0.15 and print without any support.
Printing all parts takes me about 3 hours.
You can use some sandpaper to eliminate some imperfections if you need it. Usually it's not necessary.
Step 3: Fulfill Your Pockets
There are three pockets on the BASE part:
-lowest for cash
-middle height for coins
-highest for documents and cards
Just put all that can merge inside.
Step 4: Putting Coins Plug Switch on the Right Place
Now take the other two parts and gently push the SWITCH through the flat hole which is located on the side of the CAP. When it reaches its limit, plastic knob will block the entrance. Then just push it harder until the knob will go through the hole. End of the SWITCH should be placed in area marked in circle on the photo.
The knob prevents falling of the SWITCH and keeps it tight in the cap.
Step 5: GENTLY APPLY THE CAP...
Step 6: AND IT IS READY TO USE!
