Introduction: 3mm LED Glow Box (No Soldering)
We created a simple box for displaying your LEDs. This box is made of laser cut acrylic but it can easily be made from any clear type of plastic you have laying around.
We also have this box available in a low price kit.
This box works by placing a CR927 coin battery in the center of the box and you insert two 3mm Leds on both sides. The box is a holder for the LEDs and the glow will illuminate the box.
Step 1: Materials Needed
To make it easier, this guide is based of the kit version of the glow box. You can use any clear plastic to make the top, bottom , and side frames.
The total length of the box is 40mm and the width is about 20mm. The center slot for the battery is 8mm by 3mm.
Materials Needed
Materials Needed
- (2)3mm leds
- (1) CR927 coin battery
- Acrylic frame - Top, Bottom , Sides
- Super Glue
Step 2: Bottom and Side Frame
Take the bottom and side frame. The bottom/base of the box should have slots that are 2mm by 2mm. They should be located towards the corner of the base. This is where the legs should be placed.
After you place the legs in the slots, super glue them in place.
Step 3:
Next you will insert the top of the frame to the side panels. Once this is together, super glue. This should create a box and the top should have an insert for the coin battery.
Step 4:
Finally insert the coin battery into the middle slot. Place each a 3mm Led on both ends of the box. The Led leads should sandwich between the battery.
Remember that you can make this kit from any type of plastic or any thing you may feel.
