Introduction: 4 Simple Servo Project With Arduino
What you need
1. Arduino or Arduino Clone
2. 9 gram Servo
3. about 12-20 Male to Male wires
4. 2 pot (potentiometers)
5. the servo.h and VarSpeedServo.h libraries.
6. if you want to you can make a servo shield to make it a bit neater.
Step 1: Controlling a Servo
this code will make it so when you upload it the servo will turn to the right then to the left #include <Servo.h> void setup(){ Servo servoMain; { servoMain.attach(10); } void loop() { servoMain.write(180); delay(1000); servoMain.write(0); delay(1000); }
Step 2: Random Servo
this code will make it so when you upload it the servo will randomly turn left and right. #include <Servo.h> Servo servoM; long randomNumber; void setup() { servoM.attach(10); randomSeed( analogRead(A0) ); } void loop() { randomNumber = random(0,181); servoM.write(randomNumber); delay(500); }
Step 3: Controlling Servo Speed
this code will make it so the servo will turn from 0 to 180 slowly.
#include <VarSpeedServo.h> VarSpeedServoservo; void setup() { servo.attach(10); } void loop() { servo.write(0,30,true);//you can change the speed of the servo by changing the second number. servo.write(180,30,true);//you can change the angle of the servo by changing the first number. }
Step 4: Controlling 2 Servos With 2 Potentiometers.
this code makes it so when using the pots(potentiometers) the servos will turn the same amount you turn them, and you can also use a joystick instead #include <VarSpeedServo.h> VarSpeedServo servo1; VarSpeedServo servo2; int potpin = 0; int val; int potpin2 = 1; int val1; void setup() { servo1.attach(9); servo2.attach(10); } void loop() { val = analogRead(potpin); val = map(val, 0, 1023, 0, 180); servo1.write(val); val1 = analogRead(potpin2); val1 = map(val1, 0, 1023, 0, 180); servo2.write(val1); }
