Introduction: $4 Usb Latte Foamer
Quick and easy mod to a $4 battery powered latte foamer for your office, so that you can run it off of your computer's USB port.
You love your coffee in the office, and some time you just can't run out to get one, so you brew your own.
But you can't easily get those nice lovely latte foam tops going. You could purchase expensive machines, but ... well, they are expensive. You can get cheap-oh battery operated ones, but you always are running out of battery juice, and they are not that powerful either.
So purchase one of those non-expensive ones, and follow these steps to give it USB power and more torque.
Tools you will need:
- cheap foamer
- a USB cable that won't be missed
- pliers and/or sharp knife
- soldering gun
- drill
You can get away without soldering if you want to, just twist-tie your wires. Messier, but functional.
- cheap foamer
- soldering gun
- drill
Step 1: First Step.
First, you will need to cut the end of the Usb wire that otherwise would connect your external device to you computer.
Step 2: Second.
Next, you will need to expose the black and red wires that run inside the USB cable, and strip the ends.
Also, gently force the two sides of the foamer apart to expose the battery terminals.
By default this particular foamer required two AA batteries (supplying 3V of DC current to the motor).
The motor in this foamer will handle the 5 Volts coming from your computer through USB cable.
And it will also result in a more powerful whipping action.
Step 3: Third Step.
Solder the black and red wires to the battery terminals.
It doesn't matter which one makes it to which terminal. The motor will just turn in one direction or in the other, depending on which one gets the positive and negative. Foam will form in your coffee independent of the rotating direction of the motor.
Tie a knot on your USB cable, so that we won't be tugging on the soldering contacts later on.
Step 4: Amost Done.
Re-assemble the foamer by gently pushing the two sides together.
Drill a hole the size of the USB cable on the side of the unit, so that you can close "battery compartment" by guiding the USB cable through it.
Close, and you are done!
Enjoy your lattes!!!
