Introduction: 4*4*4 LED CUBE
A SIMPLE 4*4*4 LED CUBE USING ARDUINO NANO
Step 1: Get the Materials
1.5mm 64 LED's
BIG FLAME 5mm Blue Clear LED(Light Emitting Diode) -100Pcsamazon.in
2. arduino nano
SunRobotics Arduino Nano V3 (ATMEGA328P) with USB Cable Compatible with All Arduino IDE
3. 4*100 ohm resistors(brown black brown )
ELECTROBOT 100 PCS 100 OHM CARBON FILM RESISTORS .25 WATT TOLERANCE 5%
4.connecting wire
5. PCB
TOOLS
1.SOLDERING IRON and LEAD
2.GLUE GUN
3.MULTIMETER
4.DRILLER
brain of my project is arduino nano
Step 2: LET's Make the Cube
make a rough layout in cardboard or wood
drill 5 mm holes using 5 mm drill bit(here i am showing 5*5*5 JIG)
Prepare the LED's
before soldering test all led's with multimeter
use pliers and make a 90° bend in cathode (- ve)
and again bend 90° (see the pictures)
keep repeating this until all of your 64 LED's are prepared
insert 16 led's in jig and solder all anodes together
each layer consists 16 led's with a common anode(+)
make 4 layers like this
now solder cathodes together(first coloumns cathode solder to the first coloumn cathode of second layer )
finally we get 4 anode layers and 16 cathode coloumns
Step 3: Circuit Diagram
from bottom
LAYER 1 CONNECT TO ARDUINO PIN A0
LAYER 2 CONNECT TO ARDUINO PIN A1
LAYER 3 CONNECT TO ARDUINO PIN A2
LAYER 4 CONNECT TO ARDUINO PIN A3
COLUMN 1 TO ARDUINO PIN A4
COLUMN 2 TO ARDUINO PIN A5
COLUMN 3 TO ARDUINO PIN D0
COLUMN 4 TO ARDUINO PIN D1
COLUMN 5 TO ARDUINO PIN D2
COLUMN 6 TO ARDUINO PIN D3
COLUMN 7 TO ARDUINO PIN D4
COLUMN 8 TO ARDUINO PIN D5
COLUMN 9 TO ARDUINO PIN D6
COLUMN 10 TO ARDUINO PIN D7
COLUMN 11 TO ARDUINO PIN D8
COLUMN 12 TO ARDUINO PIN D9
COLUMN 13 TO ARDUINO PIN D10
COLUMN 14 TO ARDUINO PIN D11
COLUMN 15 TO ARDUINO PIN D12
COLUMN 16TO ARDUINO PIN D13
Step 4: BASE FOR CUBE
make a cardboard base
Step 5: PROGRAMMING
HAPPY MAKING
THANKS
