Introduction: 4G LTE SPEED BOOSTER
Now a days, almost every person use internet. And maximum of them use wireless internet e.g. WiFi, 3g, 4g.
But internet speed has fallen down. The cause may be too much congestion or weak signal problem.
Today I'll show you how to boost 3g/ 4g internet speed. I made the tutorial video prior, you can check it out here.
Step 1: TAKE FIBRE SHEET AND CUT IT INTO 25X16 CM.
find fibre or plastic sheet strong enough to hold the curve shape. You may find it from old scratches or any old machine such as printer, box etc. Measure and cut it into size 25x16 cms.
Step 2: Curve It Down
curve it by simply heating it into gas burner or heat blower. Hold it to the desired position when it is mild hot and let it cool down.
Step 3: Prepare Your Glue
prepare your glue by mixing it. And apply on the outer curved surface.
Step 4: Paste Alluminium Foil
paste aluminium film at outer surface of the curved sheet.
IF YOU DON'T KNOW WHERE TO GET FREE ALLUMINIUM AND COPPER FOIL FROM SCRATCHES WATCH THIS
https://youtu.be/rDtQmOlDuhE
Step 5: Let It Dry for 5 Minutes
wait and let it dry.
Step 6: PREPARE THE INNER SIDE
Now paste the copper foil at the inner side of the sheet.
Paste it on both ends leaving a gap between. As shown in the picture.
Step 7: PREPARE THE CENTRE ELEMENT
Now paste a squared copper foil at the centre and cut out the foil as shown in picture.
Make sure that both ends are attached to copper foil. If not solder it.
Step 8: READY FOR USE
Now it is ready for use, place your router at the centre of antenna as shown in picture.
For full steps and testing please watch this video.
https://youtu.be/PTqQwot74Sw
Step 9: RESULT
Here you may see, I have made two testing.
Upper one is with booster and lower result is without booster.
It increased speed about 1mbps.
If you face the booster towards the cell tower, in the correct angle, it will boost more.
You need to experiment on it to find best position for your booster.
Thanks for viewing.
Refer to video for detailed information.
