Introduction: 60 Second Mobile
Sometimes great works of art come from inspiration. Other times they spring forth fully formed from the cosmic chaos. This project is one of the latter. It uses the power of serendipity to pull a creative project out of ... well, out of a box of hangars.
After a recent move an organized group of wire hangars were inadvertently tossed into an empty box. When I reached in to pull it out I found the hangars had merged into a spontaneously generated kinetic sculpture. So instead of crying over spilt hangars I hung it on a tree.
Step 1: Materials an Tools
Skills: To do this project you need to be able to confidently do the following:
Materials:
- Drop things.
- Shake a box.
- Grab something.
- Hang something.
Materials:
- Wire hangars. (Any make, model, or color.)
- Tree. (Any make, model, or color.)
- Cardboard box. (American Value 2 Ply brand only. Cannot guarantee results with other medium-to-large cardboard boxes.)
- Pliers (Optional.)
Step 2: Drop Hangars Into the Box.
Drop the hangars into the cardboard box. Allow gravity to pull them in, you don't need to force them. Make sure none of the hangars miss the box. If they do, pick them up and drop them in the box.
Step 3: Shake the Box
Vigorously shake the box for a minute. (You may need a stopwatch or timer to time the shaking.) Be sure to turn it both back and forth while shaking. Shaking the box in only in one direction (either back or forth) is not recommended.
Step 4: Grab
Due to the precisely timed shaking in the previous step all of the hangars will now be almost permanently interlocked.
Sit the box down on a sturdy, level, flat surface and grab the first hook you see and lift directly up.
Step 5: Hang
Place the hangar over a sturdy accessible branch of a nearby tree.
Wait for a gentle breeze to animate your fantastic creation. Enjoy the soothing sounds it makes.
If you want to make it a bit more durable and weather resistant go after it with a pair of piers to bend and crimp some of the more precarious connections.
