Introduction: 7 Layer Frozen "Breakfast"
About: Seeker of new inspiration, fearless adventurer, boldly making my happy :)
This delicious treat is comprised of seven layers of breakfast inspired flavors contained within a chocolate sphere. This treat may be served without the sphere or in any combination of the 7 layer elements. Create a combination that sets your taste buds free!
Step 1: Brown Butter & Bacon Ice Cream
INGREDIENTS & TOOLS
6 Cups Heavy Cream
4 ½ Cups Half & Half
1 ¼ Cups Sugar
1 Cup Brown Sugar
1 ½ Tbsp Vanilla
1 Package Bacon (approx. 14 slices)
1 Cup unsalted butter (2 sticks)
Ice Cream Maker
BROWN BUTTER
  • Melt the butter in a skillet, stirring occasionally until the butter is brown and smells toasted. Add in ¾ cup of brown sugar. Remove from the heat and let cool.
BACON
  • Cook bacon until crispy. While still hot, sprinkle with remaining brown sugar. Crumble when completely cooled.
ICE CREAM BASE
  • Combine all ingredients EXCEPT bacon into a container and prepare to add it to your ice cream maker.
  • Follow the operating instructions specific to your ice cream maker. If you are looking for an ice cream maker, I use the Nostalgia 4 quart and have been very happy with the results. The operating instructions are simple, and the ice cream comes out creamy.
  • Once the churning process has completed, stir in the crumbled bacon and freeze for at least 2 hours before serving.
Step 2: Orange Chantilly Creme
INGREDIENTS & TOOLS
4 ½ Cups heavy whipping cream
1 Cup confectioners' sugar
1/3 Cup orange juice
Electric Hand Mixer
  • In a large bowl, beat cream until it begins to thicken.
  • Add confectioners' sugar; beat until stiff peaks form.
  • Beat in orange juice.
Step 3: Maple Ganache
INGREDIENTS & TOOLS
9 Ounces bittersweet chocolate, chopped
1 Cup heavy cream
1 Tbsp maple flavoring
  • Place the chocolate into a medium bowl.
  • Heat the cream in a small saucepan over medium heat. Bring just to a boil. When the cream has come to a boil, pour over the chopped chocolate, and whisk until smooth.
  • Stir in the maple flavoring.
  • Allow the ganache to cool until thick, then whip with a whisk until light and fluffy.
Step 4: Coffee Water Gel
INGREDIENTS & TOOLS
1 Package Knox unflavored gelatin
¼ Cup cold coffee *sweeten if desired
¼ Cup hot coffee *sweeten if desired
  • Combine gelatin and cold coffee, allow to stand for one minute.
  • Add the hot coffee and pour the gelatin mixture onto a cookie sheet creating a thin layer of gelatin.
  • Place in refrigerator to cool and become firm.
Step 5: Cinnamon & Sea Salt Dust
INGREDIENTS & TOOLS
1 Cup Cinnamon Toast Crunch Cereal
1 Tbsp sea salt
  • Crush cereal into small pieces/powder.
  • Add in sea salt and mix.
Step 6: French Toast
INGREDIENTS & TOOLS
Sliced Bread
2 eggs
1 Tbsp cinnamon
  • Combined eggs and cinnamon.
  • Coat bread with the egg mixture and brown both sides in a skillet over medium heat.
Step 7: Orange Foam
INGREDIENTS & TOOLS
2 Cups orange juice, pulp-free works best
Electric Hand Mixer
The foam does not last for an extended period of time, this should be made right before serving.
  • Using an electric hand mixer whip surface of orange juice creating a foam. This takes some practice. I find it easiest to tilt the bowl and catch only the surface of the orange juice, allowing the foam to gather near the exposed bowl area. Use the high-speed setting.
Step 8: Chocolate Sphere
INGREDIENTS & TOOLS
2 lbs of chocolate
3-inch silicone sphere molds
Chocolate thermometer
HOW TO TEMPER CHOCOLATE
  • Place a saucepan half-filled with water over medium heat and cover with heatproof mixing bowl large enough to snugly rest on the rim of the saucepan.
  • Chop 2 pounds of chocolate into small pieces. Place about 2/3 of the chopped chocolate into the bowl.
  • Use a rubber spatula to stir occasionally until the chocolate reaches about 100°F.
  • Carefully remove the bowl from the pan and stir in the remaining chocolate.
  • As the chocolate cools to a temperature of about 83°F-84°F, you will see the chocolate start to crystallize (harden) around the outside edge of the bowl. Use the rubber spatula to stir the crystallized chocolate into the melted chocolate.
  • Being careful not to overheat it, place the bowl of melted chocolate over simmering water until the chocolate reaches the ideal working temperature of 88°F- 90°F.
  • If the chocolate is tempered, a knife tip dipped into tempered chocolate will set with a nice shine after 60 seconds in the refrigerator.
  • Now you are ready to use the tempered chocolate!
CREATING THE SPHERE
  • Using a small basting brush, coat the inside of the silicone molds. Allow to dry and apply a second coat., the layers will not take long to dry.
  • Once the molds are dry, carefully remove the chocolate.
  • Cut holes into one half of a sphere. This will serve as your sphere top. To do this you will need a metal cake decorating tip. Warm the opening of the decorating tip in a cup of hot water and apply it to the chocolate sphere. This will melt through the chocolate creating a hole.
Step 9: Assemble the Layers
Begin with the bottom half of your sphere. I like to put a small dab of ganache under the sphere to help hold it in place on the dish. When building the layers, I used a small mason jar lid to cut circular pieces of the French Toast and Coffee Gel.
  • 1st - Place the French Toast in the bottom of the sphere
  • 2nd - Top with a small amount of maple ganache
  • 3rd – Add a layer of coffee gel
  • 4th - Drip a small amount of the orange foam into the cavities created by the layers
  • 5th – Add a layer of orange Chantilly
  • 6th – Top with the brown butter & bacon ice cream
  • 7th – Sprinkle the cinnamon sea salt dust over the ice cream
Step 10: Sealing the Sphere
  • Heat a skillet.
  • Set the top dome of your sphere (with the holes cut out) in the skillet. It will begin to melt the edges within seconds.
  • Remove the dome top and set it onto the bottom half of the dome containing your layers.
  • The melted chocolate will harden, sealing your tasty creation into a perfect sphere.
Step 11: Enhancements
  • Brushing your sphere with a bit of edible shimmer dust will add to the wow factor.
  • Adding a bit of smoke under a glass dome will create a unique unveiling experience and infuse your treat a smoky element. A portal smoking gun is a great tool for this, I use bourbon wood chips in mine.
  • Garnish your dish with a sliced of brown sugar bacon and a little orange juice foam.
