8 LED POV Using Arduino Nano
Intro: 8 LED POV Using Arduino Nano
Hi All,
I helped my son to make the 8 LED POV for his school project. In doing so I was able to introduce him to
- Soldering
- Testing electronic components
- Arduino coding
This is a beginner's level project.. that one can start with or introduce, to your kids.
Please try it and share your feedback and comments
Information on POV: https://en.wikipedia.org/wiki/Persistence_of_vision
STEP 1: Circuit
- We are using 8 Pins (D2 to D9) from Arduino Nano
- Cathode from all LEDs are connected to GND
- We are using 100 ohms resistor to limit current
- If you are using RED LEDs instead of Green, the resistor value should be 220 ohms
- 9V battery is connected to VCC and GND Pins (we will use Arrduino's internal voltage regulator)
STEP 2: Testing Each Component
- Before we start soldering, we must test each component
- To test LEDs, we will use a 3v coin battery and test each LED
- To test the resistor, use a multimeter, Set it to measure "resistance"
- The multimeter should read values close to 100 ohms
STEP 3: Soldering LEDs
- Place 8 LEDs on the PCB, with its cathode towards the edge
- Bend all cathode and place a (non-enameled) copper wire below it
- Use Paper tape to hold them in place, while soldering
- Do not solder Anode.
- If a LED is not in alignment, adjust now by resoldering that specific LED
STEP 4: Soldering Resisters
- Place 100 OHM resistors adjacent to LED's anode
- Solder only LEDs Anode and resitor.
STEP 5: Soldering Other Components
- Add the female header pins and solder with the other end of the resistor
- Solder a copper jumper wire, connecting the common cathode of LEDs to the GND pin of Arduino nano
- Solder +ve and -ve wire from the battery holder to VCC and GND (respectively) pins of the Arduino nano
STEP 6: Finishing
- To demonstrate the effect of POV, we need to swing the circuit fast
- For this, we need to stick the circuit on a wooden stick
- You can use double side tape or hot glue gun for this
STEP 7: Coding
- Code is available on https://github.com/amit-jain-diy/blog/blob/main/Ardunio_CODE/POV_8led2/POV_8led2.ino
- Arduino IDE Setting
- Board: Arduino Nano
- Com Port: <select correct one>
- Processor: ATmega328P (Old Bootloader)
- Upload the code to nano
- It should display WOW as text
- You can change this to anything you like
- Best results in dark environment
Please share your comments and suggestions
