Introduction: Engineering a 2D Printed Logo Into a 3D Object
This project describes how to turn an image of a logo into a printable 3D object
Tools: Adobe Photoshop, Illustrator, Autodesk 123D Design
No drawing required!
Instructions Courtesy of Rick Valdez
Step 1: Open Original Image in Adobe Photoshop
Open image of logo in Adobe Photoshop
Step 2: Adjust Levels
A. Open the Levels dialog box (Command-L)
B. Slide the left arrow in the histogram to the right to increase contrast
Step 3: Select Outer Area of Image
A. Select a square of the outer area
B. Choose “Similar” from the Select menu
Step 4: Clear the Background
Select “Clear” from the Edit menu
Step 5: Save Image As PSD
Save the image without the background as a Photoshop file
Step 6: Open File in Adobe Illustrator
Open the Photoshop PSD file in Adobe Illustrator
Step 7: Use Image Trace to Create Outline
A. Using the Magic Wand Tool, click on the image of the elephant
B. Select “Image Trace” from the Windows menu
Step 8: Activate Image Trace
Click the “Image Trace” button
Step 9: Expand to Add Bezier Curve
Click the “Expand” button
Step 10: Stroke Bezier Curve
A. IMPORTANT: Add 1 pt. stroke
B. Choose zero Fill to check
Step 11: Isolate the Logo
A. Select the white arrow Direct Selection Tool
B. Surround the logo with the tool to highlight all the points
C. Copy the logo to the Clipboard (command-C)
Step 12: Paste Clean Logo Into New Document
A. Open a new document
B. Paste the logo into the new document. Ensure that the bounding box only includes the logo.
Step 13: Save for Export
Save a copy as Format: Illustrator EPS
Step 14: Launch 123D Design Online
A. Launch Autodesk’s 123DApp.com
B. Select “Launch 123D Design Online”
Step 15: Import EPS
Select “Import...” from the File menu
Step 16: Image Placement
The image is placed
Step 17: Selecting Press/Pull Menu
A. Move the model and magnify in
B. Select “Press/Pull” from under Finishing Tools
Step 18: Extrude Model
Pull the controls to add dimension to the EPS file.
Step 19: Save File to Autodesk Cloud
Save Project to Private storage
( Requires free Autodesk account )
Step 20: Open in Autodesk 123D Design APP
A. Open the Autodesk 123D Design App ( Free application )
B. Show as “Materials and Outlines”
Step 21: Save As STL for Printing
Export as STL file
Note: Imported models have many data points. Expect slow response times.
Step 22: Send to Printer
Provide STL File to 3D Service Bureau or print on your own printer
