Introduction: A Rainbow Made From 1026pcs 5mm Magnetic Balls
About: Unleash your imagination and creativity
A rainbow is a meteorological phenomenon that appears as a multicoloured circular arc, usually identified as red, orange, yellow, green, blue, indigo, and violet. It is caused by refraction of the sun's rays by rain and appears in the section of sky directly opposite the sun as a result of the reflection, refraction and dispersion of sunlight in water droplets.
In this post, I show you how to build a rainbow from 1026pcs 5mm magnetic balls.
371 pieces 5mm red magnetic balls
114 pieces 5mm orange magnetic balls
114 pieces 5mm gold magnetic balls
114 pieces 5mm green magnetic balls
114 pieces 5mm blue-ish green-ish magnetic balls
114 pieces 5mm blue magnetic balls
85 pieces 5mm purple magnetic balls
Step 1: Make a Ring With 7 Red Balls, 2 Orange Balls, 2 Gold Balls, 2 Green Balls, 2 Blue-ish Green-ish Balls, 2 Blue Balls and 1 Purple Ball.
Step 2: Make a Ring With 6 Red Balls, 2 Orange Balls, 2 Gold Balls, 2 Green Balls, 2 Blue-ish Green-ish Balls, 2 Blue Balls and 2 Purple Ball.
Step 3: Now We Have 2 Rings.
Step 4: Stack Them Together.
Step 5: Pinch the Top Ring to Make a Triangle.
Step 6: We Need 4 Triangles.
Step 7: Put Them Together.
Step 8: Push Every Corner of the Triangle Stack.
Step 9: We Need 7 Triangle Stack.
Step 10: Put Them Together.
Step 11: Make a Ring With 7 Red Balls, 2 Orange Balls, 2 Gold Balls, 2 Green Balls, 2 Blue-ish Green-ish Balls, 2 Blue Balls and 1 Purple Ball.
Step 12: Pinch the Ring to Make a Triangle.
Step 13: Put the Triangle on the Rear of the Triangle Stack.
Step 14: Push Every Corner of the Triangle We Just Placed.
Step 15: Pinch the Balls on the Corner of the Triangle Stack to Make a Curve.
Step 16: Turn the Rainbow Vertical.
Step 17: Here Is the Complete Rainbow Made From 1026pcs 5mm Magnetic Balls.
