Introduction: A Ring Out of a Tin Can
Please be patient as this is my first instructable.
Step 1: Materials
Materials you'll need include
A tin can
Plyers
Can opener
Scissors
Super glue
Sand paper
Tape (optional)
Duck tape (also optional)
Step 2: Cut the Top Ring Off
This step is simple enough, all you need to do is cut the top ring off to create a flat surface.
Step 3: Cut a Strip Off
Next take a pair of scissors or metal cutters and cut a strip a bit wider than you want the ring to be. I made the mistake of not using scissors the first time so my first one was very jagged.
Step 4: Trim Down to Size
This can just be done with scissors and is simple enough
Step 5: Mark Your Finger Size
Wrap it around your finger once pretty loose and mark it, you will then want to cut a little off each side from the mark down.
Step 6: Final Step, Glue It
Curl it around your finger to the mark you made earlier, then put a dot of glue on and roll it up a little continue this until you reach the end, then put a dot of super glue on hold in place till it dries (I used pliers and held them together using tape) you can sand down the sides if you want, also you can line the inside with duck tape for added comfort. Thanks and i hope you've enjoyed this instructable.
